one ADSL link switching off another
gnich
Hi all,
Been working to get a 2811 with 4 ADSL cards working, thanks for the help so far.
Line 2 is currently connected to a different router so can't se i
Line 0, 1 and 3 work on there own.
Line 1 works with line 3
The big problem now is than when I enable line 0 it causes line 3 to stop working
I can not check line 0 to line 1 as there is an IP allocation issue (both on the same subnet)
Any suggestions on wgat might be wrong with line 0.
Ta Graham
Giuseppe Larosa
Hello Graham,
I would suggest you to go on the other thread there is no use on opening a second thread for the same issue.
Best Regards
Giuseppe
