Showing results forĀ
Search instead forĀ
Did you mean:Ā
One Router and Two Interfaces on the same network
Borman Bravo
Hi, thanks in advance for your comments, I have one router and two lan interfaces that need to be on the same network just to provide interface redundancy in  the event that one of them or the attached switch fails, besides configuring a BVI to bridge them, is there any other option to have these 2 lan interfaces on the same /24 network? I've had some issues with the BVI setup when traffic was not crossing the bridge. Thanks again.
cadet alain
apart from bridging I don't see how you could have 2 interfaces in same subnet except maybe in 2 VRFs.
Regards.
Alain
Amit Singh
Which router is that? Do you have a modular slot available? As Alan mentioned BVI is the only option in this set up. I would buy another router to provide the optimum redundancy in my network and configure HSRP for an automatic failover.Another option could be to buy a 4/9 port ether switch module, configure the trunk ports down to the access switches and create SVI's on the router. I have not tried that but this should work.
Hope this helps.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of    this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising   out of the use or inability to use the posting's  information even if   Author has been advised of the possibility of such  damage.
Posting
One possible option might be to port channel your two router interfaces.
