one telnet session is working
aircel.dishnet
Hi All,
We are facing telnet issue in one of our 7206 VXR router .We can able to ping this router from its directly connected neighbor but can't able to telnet it.
At the same time we can able to access this device from another router.But it is accepting only one session at a time.
Please help.
sh run | be line
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
session-timeout 7
exec-timeout 7 0
line vty 5 15
session-timeout 7
exec-timeout 7 0
Cisco IOS Software, 7200 Software (C7200-K91P-M), Version 12.2(25)S9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 28-Mar-06 23:12 by alnguyen
ROM: System Bootstrap, Version 12.3(4r)T1, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(9), RELEASE SOFTWARE (fc2)
BBNR-7206-EDGE1 uptime is 1 year, 11 weeks, 6 days, 14 hours, 0 minutes
System restarted at 00:50:35 IST Fri May 25 2012
System image file is "disk2:c7200-k91p-mz.122-25.S9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G1) processor (revision B) with 229376K/32768K bytes of memory.
Processor board ID 32638124
SB-1 CPU at 700Mhz, Implementation 1025, Rev 0.2, 512KB L2 Cache
thanks,
Arun Mohan
John Blakley
Have you verified there aren't any locked sessions on the device? On the one that you can telnet into, try issuing a "show users" and see if you're session is truly the only one. If there are others that shouldn't be there, you can close them with "clear line vty ".
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
