We have a flat network, Cisco 881 router > Switch > Polycom Video Conference device
I have successfuly statically NATed the Polycom device to public IP but then it seems that the video traffic is not going in.
Ive NATed 192.168.1.50 : 115.42.184.XX
Im trying to open ports using access list.
TCP: 3230 - 3235
UDP: 3230 - 3235
TCP: 1720
UDP: 1720
but no luck, please kindly advise,
Here is the config of the router
SNR_Denton-881#sh run
Building configuration...
Current configuration : 3576 bytes
! Last configuration change at 06:24:06 UTC Tue Jul 9 2013 by admin
! NVRAM config last updated at 04:01:12 UTC Sat Jul 6 2013 by admin
version 15.0
no service pad
hostname SNR_Denton-881
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-2315253159
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2315253159
revocation-check none
rsakeypair TP-self-signed-2315253159
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp pool sdm-pool
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 165.21.100.88 165.21.83.88
lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO881-K9 sn FGL160525C3
username privilege 15 password 0
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 115.42.131.XX 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex full
speed 100
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 101 interface FastEthernet4 overload
ip nat inside source static 192.168.1.50 115.42.184.XX
ip nat inside source static 192.168.1.51 115.42.184.XX
ip route 0.0.0.0 0.0.0.0 115.42.131.XX
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
