operating temperature of supervisor Engine 720
szekahungdanny
Based on the following data sheet, it stated "operating temperature is from 0C to 40C".
Operating temperature: 32 to 104°F (0 to 40°C)
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856.html
however, from the following output, which items is the "operating temperature" refer?
Router#show environment alarm thresholds
environmental alarm thresholds:
power-supply 1 fan-fail: OK
  threshold #1 for power-supply 1 fan-fail:
    (sensor value != 0 ) is system minor alarm
power-supply 1 power-output-fail: OK
  threshold #1 for power-supply 1 power-output-fail:
power-supply 1 incompatible with fan: OK
  threshold #1 for power-supply 1 incompatible with fan:
fan-tray 1 fan-fail: OK
  threshold #1 for fan-tray 1 fan-fail:
    (sensor value == 1 ) is system minor alarm
operating clock count: 2
  threshold #1 for operating clock count:
    (sensor value < 2 ) is system minor alarm
  threshold #2 for operating clock count:
    (sensor value < 1 ) is system major alarm
operating VTT count: 3
  threshold #1 for operating VTT count:
    (sensor value < 3 ) is system minor alarm
  threshold #2 for operating VTT count:
    (sensor value < 2 ) is system major alarm
operating fan count: 1
  threshold #1 for operating fan count:
    (sensor value < 1 ) is system minor alarm
VTT 1 OK: OK
  threshold #1 for VTT 1 OK:
VTT 1 outlet temperature: 33C
  threshold #1 for VTT 1 outlet temperature:
    (sensor value >= 100C) is system minor alarm
  threshold #2 for VTT 1 outlet temperature:
    (sensor value >= 115C) is system major alarm
VTT 2 OK: OK
  threshold #1 for VTT 2 OK:
VTT 2 outlet temperature: 36C
  threshold #1 for VTT 2 outlet temperature:
  threshold #2 for VTT 2 outlet temperature:
VTT 3 OK: OK
  threshold #1 for VTT 3 OK:
VTT 3 outlet temperature: 39C
  threshold #1 for VTT 3 outlet temperature:
  threshold #2 for VTT 3 outlet temperature:
clock 1 OK: OK
  threshold #1 for clock 1 OK:
clock 2 OK: OK
  threshold #1 for clock 2 OK:
module 5 power-output-fail: OK
  threshold #1 for module 5 power-output-fail:
module 5 insufficient cooling: N/A
  threshold #1 for module 5 insufficient cooling:
    (sensor value != 0 ) is system major alarm
module 5 fan-upgrade required: N/A
  threshold #1 for module 5 fan-upgrade required:
module 5 outlet temperature: 29C
  threshold #1 for module 5 outlet temperature:
    (sensor value >= 50C) is system minor alarm
  threshold #2 for module 5 outlet temperature:
    (sensor value >= 65C) is system major alarm
module 5 inlet temperature: 24C
  threshold #1 for module 5 inlet temperature:
    (sensor value >= 45C) is system minor alarm
  threshold #2 for module 5 inlet temperature:
    (sensor value >= 60C) is system major alarm
module 5 device-1 temperature: 33C
  threshold #1 for module 5 device-1 temperature:
    (sensor value >= 55C) is system minor alarm
  threshold #2 for module 5 device-1 temperature:
    (sensor value >= 70C) is system major alarm
module 5 device-2 temperature: 34C
  threshold #1 for module 5 device-2 temperature:
  threshold #2 for module 5 device-2 temperature:
module 5 asic-1 temperature: 24C
  threshold #1 for module 5 asic-1 temperature:
    (sensor value >= 115C) is system minor alarm
  threshold #2 for module 5 asic-1 temperature:
    (sensor value >= 127C) is system major alarm
module 5 asic-2 temperature: 24C
  threshold #1 for module 5 asic-2 temperature:
    (sensor value >= 90C) is system minor alarm
  threshold #2 for module 5 asic-2 temperature:
    (sensor value >= 105C) is system major alarm
module 5 asic-3 temperature: 24C
  threshold #1 for module 5 asic-3 temperature:
  threshold #2 for module 5 asic-3 temperature:
module 5 asic-4 temperature: 24C
  threshold #1 for module 5 asic-4 temperature:
  threshold #2 for module 5 asic-4 temperature:
module 5 asic-5 temperature: 24C
  threshold #1 for module 5 asic-5 temperature:
  threshold #2 for module 5 asic-5 temperature:
module 5 asic-6 temperature: 24C
  threshold #1 for module 5 asic-6 temperature:
  threshold #2 for module 5 asic-6 temperature:
module 4 power-output-fail: OK
  threshold #1 for module 4 power-output-fail:
module 4 insufficient cooling: N/A
  threshold #1 for module 4 insufficient cooling:
module 4 outlet temperature: 29C
  threshold #1 for module 4 outlet temperature:
    (sensor value >= 60C) is system minor alarm
  threshold #2 for module 4 outlet temperature:
    (sensor value >= 75C) is system major alarm
module 4 inlet temperature: 28C
  threshold #1 for module 4 inlet temperature:
  threshold #2 for module 4 inlet temperature:
module 8 power-output-fail: OK
  threshold #1 for module 8 power-output-fail:
module 8 insufficient cooling: N/A
  threshold #1 for module 8 insufficient cooling:
module 8 outlet temperature: N/O
  threshold #1 for module 8 outlet temperature:
    (sensor value >= 70C) is system minor alarm
  threshold #2 for module 8 outlet temperature:
    (sensor value >= 85C) is system major alarm
module 8 inlet temperature: N/O
  threshold #1 for module 8 inlet temperature:
  threshold #2 for module 8 inlet temperature:
module 8 device-1 temperature: N/O
  threshold #1 for module 8 device-1 temperature:
  threshold #2 for module 8 device-1 temperature:
module 8 device-2 temperature: N/O
  threshold #1 for module 8 device-2 temperature:
  threshold #2 for module 8 device-2 temperature:
module 5 EARL outlet temperature: 33C
  threshold #1 for module 5 EARL outlet temperature:
  threshold #2 for module 5 EARL outlet temperature:
module 5 EARL inlet temperature: 25C
  threshold #1 for module 5 EARL inlet temperature:
  threshold #2 for module 5 EARL inlet temperature:
module 5 RP outlet temperature: 26C
  threshold #1 for module 5 RP outlet temperature:
  threshold #2 for module 5 RP outlet temperature:
module 5 RP inlet temperature: 27C
  threshold #1 for module 5 RP inlet temperature:
  threshold #2 for module 5 RP inlet temperature:
module 4 VDB outlet temperature: 25C
  threshold #1 for module 4 VDB outlet temperature:
    (sensor value >= 80C) is system minor alarm
  threshold #2 for module 4 VDB outlet temperature:
    (sensor value >= 90C) is system major alarm
module 4 VDB inlet temperature: 28C
  threshold #1 for module 4 VDB inlet temperature:
    (sensor value >= 75C) is system minor alarm
  threshold #2 for module 4 VDB inlet temperature:
module 4 VDB device-1 temperature: 28C
  threshold #1 for module 4 VDB device-1 temperature:
  threshold #2 for module 4 VDB device-1 temperature:
    (sensor value >= 80C) is system major alarm
Anyone could answer me the operating temperature of 0-40C is talking about the inlet device ? or the RP processor? or overall ?
Many Thanks.
Leo Laohoo
Whatever you do, don't try this method on the picture (attached).
The operating temp would be primarily mentioned for on board ASIC.
EG:-
module 5:
  module 5 outlet temperature: 27C
  module 5 device-1 temperature: 31C
  module 5 device-2 temperature: 31C
  module 5 asic-1 (SSO-1) temp: 25C
  module 5 asic-2 (SSO-2) temp: 24C
  module 5 asic-3 (SSO-3) temp: 25C
  module 5 asic-4 (SSO-4) temp: 24C
  module 5 asic-5 (SSA-1) temp: 25C
  module 5 asic-6 (HYPERION-1) temp: 25C
  module 5 RP outlet temperature: 27C
  module 5 RP inlet temperature: 28C
  module 5 EARL outlet temperature: 35C
  module 5 EARL inlet temperature: 21C
Thanks. But any Cisco official document could refer to?
