Optimized Edge Routing (OER) Inquiries
erbertson
Hi Folks,
In OER, the master controller uses passive monitoring to measure the delay, packet loss, reachability and throughput.
For those of you who had implemented OER, is there any tool have these information replicated on a separate medium other than the routers participating in the OER setup?
Thanks!
Erbertson
cadet alain
I've never tried but in OER passive monitoring is done with NetFlow so you can export your Netflow records to a collector.
One important point these are the border routers that do the monitoring not the master controller.
Regards.
Alain
