Optimizing BGP
Lewis Quin
We are running BGP at two sites (different locations) that also has a L2 connection connecting the two sites.  There is a DMZ that is split between the two sites (public address space) using the L2 connection.  We announce the public DMZ address space (/23) out via BGP from both locations using and AS prepend to influence the inbound traffic into "Site A".  What I would like know is if we can do the following using BGP:
Break the /23 into two smaller networks (/24) bringing the first half into 'Site A', and the second half into 'Site B', however keep both sites capable of receiving the full /23  in the event of failure.
Yes it's possible.
See the last bit I added a about an alternative way to do it.
Really up to you which you prefer.
Jon
5 Replies 5
Jon Marshall
Yes you can as long as your ISP accepts /24s.
So at site A advertise site A's /24 as normal and site B's /24 with prepending
At site B advertise site B's /24 as normal and site A's /24 with prepending.
Alternatively you could just have site A advertise it's own /24 and the summary and site B advertise it's own /24 and the summary.
There is no need for prepending then as the summary is only used if the /24 is no longer available.
Up to you really which way you do it.
Jon
Perfect, so this is possible even though both /24's (a larger /23) have the same AS#?
Yes it's possible.
Jon
Awesome, thanks for the quick response!
No problem
Personally I would use the prepending solution rather than the summary one because then there is no ambiguity in what you are advertising from which site.
And because there is a direct link between sites under some circumstances you might still be advertising the summary even if the local /24 is not available.
Jon
