OSPF-5-ADJCHG: Process 30, Nbr 192.168.1.1 on GigabitEther net0/0 from FULL to DOWN, Neighbor Down: Dead timer expired
sanjeevmahadani
Could any one suggest for the below error, and how to correct this..
Router Config:
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
  ip address 172.23.43.34 255.255.255.252
ip ospf network point-to-point
duplex full
speed 100
interface GigabitEthernet0/1
ip address 10.10.10.1 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
router ospf 30
network 172.22.0.0 0.0.3.255 area 10
network 172.23.43.12 0.0.0.3 area 10
network 172.23.43.32 0.0.0.3 area 10
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.16.71
ip route 172.22.0.0 255.255.255.0 10.10.10.2
ip route 172.22.1.0 255.255.255.0 10.10.10.2
ip route 172.22.14.0 255.255.255.0 172.23.43.13
ip route 172.22.14.0 255.255.255.0 172.23.33.10
no cdp run
snmp-server community public RO
snmp-server location SPANCO_GEMI
control-plane
line con 0
line aux 0
--More--
FW Config :
SPANCO-PRIM/pri/act# sh run
: Saved
ASA Version 8.4(2)
hostname SPANCO-PRIM
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
description " Connectivity to Firewall "
nameif outside
security-level 0
ip address 10.10.10.2 255.255.255.248 standby 10.10.10.3
interface Ethernet0/1
description "Connectivity to L3 Switch"
nameif inside
security-level 100
ip address 20.20.20.1 255.255.255.248 standby 20.20.20.2
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
description LAN/STATE Failover Interface
interface Management0/0
shutdown
nameif management
security-level 100
management-only
ftp mode passive
access-list inside extended permit ip any any
access-list inside extended permit icmp any any
access-list inside extended permit icmp any any time-exceeded
access-list outside extended permit ip any any
access-list outside extended permit icmp any any
access-list outside extended permit icmp any any time-exceeded
access-list 101 extended permit icmp any any echo-reply
access-list 101 extended permit icmp any any source-quench
access-list 101 extended permit icmp any any unreachable
access-list 101 extended permit icmp any any time-exceeded
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit icmp any any time-exceeded
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
failover
failover lan unit primary
failover lan interface SPANCO Ethernet0/3
failover polltime unit msec 200 holdtime msec 800
failover key *****
failover replication http
failover link SPANCO Ethernet0/3
failover interface ip SPANCO 1.1.1.1 255.255.255.252 standby 1.1.1.2
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
no asdm history enable
arp timeout 14400
access-group outside in interface outside
access-group inside in interface inside
route outside 0.0.0.0 0.0.0.0 10.10.10.1 1
route inside 172.0.0.0 255.255.255.0 20.20.20.6 1
route inside 172.22.0.0 255.255.255.0 20.20.20.6 1
route inside 172.22.1.0 255.255.255.0 20.20.20.6 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username cisco password 3USUcOPFUiMCO4Jk encrypted
class-map inspection_default
match default-inspection-traffic
class-map inspeection-default
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname priority state
no call-home reporting anonymous
Cryptochecksum:50f8eb9e0093ba7b40006d16b5e3f650
: end
Giuseppe Larosa
Hello Sanjeev,
the message means that OSPF adjacency on gi0/0 has fallen down because the dead interval timer has expired.
The default value od the dead interval is 40 seconds. This means that for at least 40 seconds the local node hadn't been receiving an OSPF hello message or other OSPF message from the neighbor.
My understanding is that OSPF is not running on the ASA.
You can check if the OSPF adjacency has been rebuilt with
show ip ospf 30 neighbor
You can check the OSPF adjacency uptime with
show ip ospf 30 neighbor detail
You should have only one OSPF neighbor out gi0/0 or none because you have configured ip ospf network point-to-point.
Hope to help
Giuseppe
Denise "Fish" Fishburne
Please assist.
The error message you are referring to is complaining about an OSPF neighbor on Gig0/0....Is this connecting to the FW?
duplex full
speed 100
As the other reply stated... It's your hello timers expiring.
