%OSPF-5-ADJCHG
roy.holcomb
Hi Can any one explain me what is the 5 stands for in the such error logs. I have seen many times such logs but not able to get the clarification over these numbers....
Please help...! thanks in advance.
6 Replies 6
GRANT3779
Messages beginning with % are system messages.
I believe the "5" in your case is the severity level which would be notification.
The levels are below -
0 – emergency
1 – alert
2 – critical
3 – error
4 – warning
5 – notification
6 – informational
7 – debugging
I believe that Grant has it right. +5 for you.
Rick
Rick
roy.holcomb
Ok Grant, i can be agree with you here. But again in this such alert message "%LINEPROTO-5-UPDOWN: " now what is the 5 stands for.... is this only means notification on any such number of count.
This message (or event) is also classed as a severity 5. Cisco class this as a 'normal, but significant condition'
As an example from one of my own switches - Two of the messages are classed as Severity 4 (Warning) The other is a Severity 5 (Notification)
Dec 15 01:23:56: %SW_MATM-4-MACFLAP_NOTIF: Host b4e1.c4ca.6618 in vlan 781 is flapping between port Gi4/0/1 and port Po10
Dec 15 03:00:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/22, changed state to down
Perhaps you'll find this document helpful as well: Cisco System Messages
"SEVERITY is a single-digit code from 0 to 7 that reflects the severity of the condition. The lower the number, the more serious the situation. Table 1  lists the severity levels."
Rolf
