OSPF adjacency is not established.
oldvoffka
OSPF adjacency is not established. HELP.
router1(X)async1/10----[modem1]------leased line------[modem2]----Serial0/2/2(X)router2
router1#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(8a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 19-Jul-06 23:21 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
router1 uptime is 13 weeks, 4 days, 17 hours, 29 minutes
System image file is "flash:c2800nm-ipbase-mz.124-8a.bin"
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FCZ10407230
2 FastEthernet interfaces
5 Serial interfaces
16 terminal lines
5 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
router1#
router1#sh run
interface Async1/10
description Link to router2
bandwidth 20
ip address 10.5.253.117 255.255.255.252
encapsulation ppp
async mode dedicated
router ospf 200
log-adjacency-changes
network 10.5.253.116 0.0.0.3 area 200
line 1/10
modem InOut
stopbits 1
speed 57600
flowcontrol hardware
router1#
router1#sh ip ospf int as1/10
Async1/10 is up, line protocol is up
Internet Address 10.5.253.117/30, Area 200
Process ID 200, Router ID 10.105.254.194, Network Type POINT_TO_POINT, Cost: 5000
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
Hello due in 00:00:05
Supports Link-local Signaling (LLS)
Index 1/1, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 0
Last flood scan time is 0 msec, maximum is 0 msec
Neighbor Count is 0, Adjacent neighbor count is 0
Suppress hello for 0 neighbor(s)
router1#sh int as1/10
Hardware is CD2430 in async mode
Description: Link to router2
Internet address is 10.5.253.117/30
MTU 1500 bytes, BW 20 Kbit, DLY 100000 usec,
reliability 255/255, txload 1/255, rxload 12/255
Encapsulation PPP, LCP Open
Open: IPCP, loopback not set
Keepalive not set
DTR is pulsed for 5 seconds on reset
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d20h
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 15 kilobits/sec
5 minute input rate 1000 bits/sec, 3 packets/sec
5 minute output rate 0 bits/sec, 2 packets/sec
669 packets input, 47196 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2525 packets output, 101721 bytes, 0 underruns
0 output errors, 0 collisions, 199 interface resets
0 carrier transitions
router1#
________________________________________________________________________________ ________
router2#sh run
interface Serial0/2/2
physical-layer async
bandwidth 20
ip address 10.5.253.118 255.255.255.252
ip load-sharing per-packet
encapsulation ppp
router ospf 200
router2#sh int s0/2/2
Serial0/2/2 is up, line protocol is up
Hardware is HWIC-Serial
Description: Link to router1
Internet address is 10.5.253.118/30
MTU 1500 bytes, BW 20 Kbit/sec, DLY 100000 usec,
Keepalive not set
Last input 00:02:32, output 00:02:32, output hang never
Last clearing of "show interface" counters 2d01h
Conversations 0/3/16 (active/max active/max total)
244 packets input, 31242 bytes, 0 no buffer
303 packets output, 12711 bytes, 0 underruns
0 unknown protocol drops
DCD=up DSR=up DTR=down RTS=down CTS=up
router2#sh ip ospf interface s0/2/2
Internet Address 10.5.253.118/30, Area 200
Process ID 200, Router ID 10.5.253.118, Network Type POINT_TO_POINT, Cost: 5000
No Hellos (Passive interface)
Cisco NSF helper support enabled
IETF NSF helper support enabled
Next 0x0(0)/0x0(0)
router2#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 14:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
router2 uptime is 2 days, 19 hours, 16 minutes
System image file is "flash:c2800nm-ipbase-mz.124-15.T10.bin"
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FHK1346F2R6
4 Low-speed serial(sync/async) interfaces
router2#
Thanks Ryhor,
Did you try configuring command "async default routing" on both sides. I think that is needed on AS for OSPF to work.
Nik
HTH,
Niko
6 Replies 6
nkarpysh
To Start with:
- can you ping successfully between those serial interfaces?
- Does your provider allow multicast on the leased line?
- you can "debug ip ospf" to see what is going on.
Nik
HTH,
Niko
1)
router2#ping 10.5.253.117
Sending 5, 100-byte ICMP Echos to 10.5.253.117, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 176/206/227 ms
router2#
2)
leased line - it is only 4-wired leased line. Modems  conected at 19200 bits/s
router2#ping 224.0.0.5
Sending 1, 100-byte ICMP Echos to 224.0.0.5, timeout is 2 seconds:
Reply to request 0 from 10.5.253.117, 404 ms
router2#
Thanks Ryhor,
Nik
HTH,
Niko
oh i am sorry, there was a mistake! there is on on side (router1 async interface):Hello due in 00:00:05
but on other (router2  serial interface in async mode) No Hellos (Passive interface)
But on router1  on other async interface OSPF works.
Oh!!! It's great? after configuring command "async default routing" on both serial and async interfaces, OSPF adjacency  established
router2#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.105.254.194         0   FULL/  -        00:00:32    10.5.253.117    Serial0/2/2
router2#
router1#sh ip ospf nei
10.5.2.174        0   FULL/  -        00:00:35    10.5.253.118    Async1/10
router1#
Thank You, Nikolay Karpyshev!
Glad it is wo0rking now. You can mark my answer as a correct one to close this thread and make it usefull for others later.
Cheers,
Nik
HTH,
Niko
