OSPF Adjchg error, adj-5-parent error, recursive routing error in PT
George Vanyan
Basically, I have created a GRE tunnel
I'd put Packet Tracer file, but the discussion won't accept the format
these are the networks
OSPF 10
area 0
GRE tunnel
172.16.100.0 /30
CS1-R1 net
192.168.1.0 /30
R1-ISP net
1.1.1.0 /30
R2-ISP net
1.1.1.4 /30
R2-CS2
192.168.2.0 /30
The errors started randomly 10-15 minutes after finalizing the setup
you can check everything in the command log. There is a chance I am missing something, a newbie yet
these are the errors from R1
00:20:10: %OSPF-5-ADJCHG: Process 10, Nbr 5.5.5.5 on Tunnel1 from LOADING to FULL, Loading Done
00:20:50: %OSPF-5-ADJCHG: Process 10, Nbr 5.5.5.5 on Tunnel1 from FULL to DOWN, Neighbor Down: Dead timer expired
00:20:50: %OSPF-5-ADJCHG: Process 10, Nbr 5.5.5.5 on Tunnel1 from FULL to DOWN, Neighbor Down: Interface down or detached
Error from R2:
03:20:53: %OSPF-5-ADJCHG: Process 10, Nbr 4.4.4.4 on Tunnel1 from LOADING to FULL, Loading Done
%ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of 1 65E900C0 - looped chain attempting to stack
%TUN-5-RECURDOWN: 1 temporarily disabled due to recursive routing
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
03:21:03: %OSPF-5-ADJCHG: Process 10, Nbr 4.4.4.4 on Tunnel1 from FULL to DOWN, Neighbor Down: Interface down or detached
18 Replies 18
100% agree. this is weird
I entered No default-information originate on R1 and no more errors occured, I'm still really new to networking, so might miss something obvious, but probably this was PT bug
It can be PKT bug
interface Tunnel0
ip address 5.0.0.2 255.255.255.0
tunnel source Ethernet0/0
tunnel destination 100.0.0.1
interface Ethernet0/0
ip address 100.0.0.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
interface Ethernet0/1
ip address 20.0.0.2 255.255.255.0
ip nat inside
router ospf 5
network 5.0.0.0 0.0.0.255 area 0
network 20.0.0.0 0.0.0.255 area 0
ip route 0.0.0.0 0.0.0.0 100.0.0.1
Thanks for checking, I agree, that was a packet tracer behaviour
