OSPF Adjchg error, adj-5-parent error, recursive routing error in PT
George Vanyan
Basically, I have created a GRE tunnel
I'd put Packet Tracer file, but the discussion won't accept the format
these are the networks
OSPF 10
area 0
GRE tunnel
172.16.100.0 /30
CS1-R1 net
192.168.1.0 /30
R1-ISP net
1.1.1.0 /30
R2-ISP net
1.1.1.4 /30
R2-CS2
192.168.2.0 /30
The errors started randomly 10-15 minutes after finalizing the setup
you can check everything in the command log. There is a chance I am missing something, a newbie yet
these are the errors from R1
00:20:10: %OSPF-5-ADJCHG: Process 10, Nbr 5.5.5.5 on Tunnel1 from LOADING to FULL, Loading Done
00:20:50: %OSPF-5-ADJCHG: Process 10, Nbr 5.5.5.5 on Tunnel1 from FULL to DOWN, Neighbor Down: Dead timer expired
00:20:50: %OSPF-5-ADJCHG: Process 10, Nbr 5.5.5.5 on Tunnel1 from FULL to DOWN, Neighbor Down: Interface down or detached
Error from R2:
03:20:53: %OSPF-5-ADJCHG: Process 10, Nbr 4.4.4.4 on Tunnel1 from LOADING to FULL, Loading Done
%ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of 1 65E900C0 - looped chain attempting to stack
%TUN-5-RECURDOWN: 1 temporarily disabled due to recursive routing
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
03:21:03: %OSPF-5-ADJCHG: Process 10, Nbr 4.4.4.4 on Tunnel1 from FULL to DOWN, Neighbor Down: Interface down or detached
2 Accepted Solutions
Hello
You have recursive routing - the tunnel source/destinations are being learned through the tunnel itself, hence the error logging.
you need to negate advertising tunnel source/destination subnets via the tunnel
Kind Regards
Paul
I entered No default-information originate on R1 and no more errors occured, I'm still really new to networking, so might miss something obvious, but probably this was PT bug
18 Replies 18
Hi @George Vanyan ,
The issue is that the tunnel destination on R1 and R2 is being learnt via ospf and that creates a loop. You need to configure a static route on R1 and R2 for the tunnel destination.
R1:
ip route 1.1.1.6 255.255.255.255 1.1.1.1
R2:
ip route 1.1.1.2 255.255.255.255 1.1.1.5
This will take care of the loop.
ip route 0.0.0.0 0.0.0.0 1.1.1.1 111
Remove this ip route 172.16.100.2 255.255.255.255 GigabitEthernet0/0/0
Remove this ip route 172.16.100.2 255.255.255.255 1.1.1.1
ip route 0.0.0.0 0.0.0.0 1.1.1.5 111
Remove this ip route 172.16.100.1 255.255.255.255 GigabitEthernet0/0/0
Remove this ip route 172.16.100.1 255.255.255.255 1.1.1.5
Also NAT with overload config' I dont get it' can you more elaborate more about this config.
yeah, NAT overload enables PAT which was actually needed to block the traffic in the 10.10.1.0; 2.0; 3.0; 4.0; 5.0 and 6.0 networks from moving via ISP router. It should've made the traffic move via only the tunnel. that was the idea
here's how it all looks
George Vanyan
both recommendations implemented - same error occurs
Only remove  the NAT from both side  and check
no ip nat inside source list GRE interface
GigabitEthernet0/0/0 overload
this one is needed, right
Yes I think it NATing issue if you remove static route I mention before.
For recursive routing it happened when you run routing protocol in tunnel have AD better than routing protocol for tunnel source
Here ospf ad=90 and default route ad=1
So I think it NATing issue.
How I know that I run one time lab for dmvpn the tunnel flapping when NAT is config.
So we need to exclude gre from NAT
Deny gre any any I think is need.
I am out now when back home I will check again.
Hello
Kind Regards
Paul
apologies I see @Harold Ritter  has already provides a solution
Kind Regards
Paul
@Harold Ritter ' s solution did not work
@George Vanyan ,
Configuring the tunnel destination as a static route towards the ISP is a very commonly seen solution to ensure that you do not get into a loop. I am not sure why it didn't work for you.
