OSPF and EIGRP
Rafael Jimenez
Level 4
Level 4
I had to setup and router with both protocols, im receiving the provider with the lan interface in area 1. I want change the configuration on my router to continous using ospf and additionaly i want setup other protocol like eigrp for other new provider.
how it is possible?
thanks.
Edison Ortiz
router ospf 1
network [interface connected to ISP1] area 1
router eigrp 1
network [interface connected to ISP2]
no auto-summary
HTH,
__
Edison.
Hi Edinson, my question is the network entry in the router eigrp 1 command is only the interface conected to the isp2?, can I select specific interfaces (or subnets) to participate in the dinamic routing (the entries in the router eigrp 1 command).
For example if I want the subnet 192.168.1.2 forward o route all the traffic to the isp2 , can i put this network in the network command?.
thank for your help.
Yes, you can select specific interfaces to participate in the EIGRP process.
If you want only 192.168.1.2, the commands will be as follow
router eigrp 1
network 192.168.1.2 0.0.0.0
no auto-summary
__
Edison.
