OSPF areas on the ABR
tsingletary
Simple question(s)...
In OSPF, how may areas can the ABR (7206 & 7507)including A0 handle. Also is it the number of interfaces in an Area or devices.
I hear that about 60 devices is the limit for Area 0. Is that true.Any feedback would be greatly appreciated.
Tim
Richard Burts
Tim
There is not any hard limit on the number of areas. It becomes a question of evaluating the load that the router can handle and is affected by how many other tasks the router is handling in addition to OSPF, how many areas, how many routes in each area, how many routers within the area, and most especially how much change is taking place within the areas. If you have a network that is extemly stable and the router needs to recalculate the SPF once a day then it can handle a very large number of areas. If the router is recalculating the SPF once every minute the number of areas that can be supported is much smaller.
If you look in several different sources you will probably find several different answers about how many devices can be supported. Again there is not any hard limit and it really is a question of what you expect the performance level to be. It is not a situation of up to a limit it works and beyond that limit it is broken, but is more of a situation that as the number of devices gets larger the performance becomes slower. How slow can it get before you decide that it is no longer working?
Rick
Rick
Rick,
I have always look for some magic number and every source (like you said) had something different about this issue.
Thanks again for taking the time to explain this.
Tim
pushkar1782
This link would greatly help
http://www.cisco.com/warp/public/104/1.html#t40
However there is no specific boundation..it depneds on lots of factors..whats suggested is in the link
rate if works
Thanks for your help....
