OSPF automatic WAN link shut down when packet drop reaches a pre defined level
Binu Steephen
Hi All,
Need you help..
Any configuration available in Cisco for OSPF automatic WAN link shut down or routing protocol shut  on that link when packet drop reaches a pre defined level.
Binu Steephen
on Ethernet WAN MPLS link.
OSPF will not do that.
You could use EEM for that, but I would be vary, as a proper calculation of trigger levels is not trivial.
Beside, why would you want to do that? Packet drops are caused by excess traffic, and if you shut down the link, you will have no way to carry even normal traffic.
Thanks Sir..Link is giving lots of packet drops, service provideris working on it but couldn't solve the issue..we need to shut this link when the packet drops reaches a lvel and switch over to secondary path..how EEM help..can you please share me any cisCO URL
Hello Binu,
EEM should do it for you.
For all EEM related question, post your question under "Network Management" where Joe Clark can further assist you. He's the EEM script expert.
Francisco.
