OSPF/BGP Connectivity Issues
Charlie Mayes
                        Hello Guys,
                                        I have 2 routers running OSPF I one network that connects to a bgp network and and trying to ping from my OSPF stub router to the iBGP network however the ping fails. I can ping the directly connected OSPF neighbor fine hoever when I attempt to ping the same router using the iBGP IP address it fails. WHY is this? The 3 router configs are below. I have other BGP routers runnning behind that borger router but can ping any o them from the STUB router. Thanks.
This is the stub config
hostname BB1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface FastEthernet0/0
ip address 172.16.12.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
router ospf 1
log-adjacency-changes
network 172.16.12.0 0.0.0.255 area 0
ip http server
ip forward-protocol nd
control-plane
mgcp behavior g729-variants static-pt
line con 0
line aux 0
line vty 0 4
login
end
This is the router that is running OSPF and BGP
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 10.12.1.2 255.255.255.252
duplex auto
speed auto
ip address 172.16.12.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
router ospf 1
router bgp 7500
no synchronization
bgp log-neighbor-changes
network 10.12.1.0 mask 255.255.255.252
neighbor 10.12.1.1 remote-as 7500
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 10.13.1.1 255.255.255.252
duplex auto
speed auto
ip address 10.14.1.1 255.255.255.252
duplex auto
speed auto
ip address 10.12.1.1 255.255.255.252
duplex auto
speed auto
router bgp 7500
no synchronization
network 10.13.1.0 mask 255.255.255.252
network 10.14.1.0 mask 255.255.255.252
neighbor 10.12.1.2 remote-as 7500
neighbor 10.13.1.2 remote-as 5000
neighbor 10.14.1.2 remote-as 2500
neighbor 10.14.1.2 password cisco
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R3
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 10.13.1.2 255.255.255.252
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 5000
no synchronization
network 10.13.1.0 mask 255.255.255.0
neighbor 10.13.1.1 remote-as 7500
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 10.14.1.2 255.255.255.252
duplex auto
speed auto
ip address 10.45.1.4 255.255.255.0
duplex auto
speed auto
ip address 10.46.1.4 255.255.255.0
duplex auto
speed auto
router bgp 2500
no synchronization
network 10.45.1.0 mask 255.255.255.0
network 10.46.1.0 mask 255.255.255.0
network 10.140.1.0
network 10.140.1.0 mask 255.255.255.252
neighbor 10.14.1.1 remote-as 7500
neighbor 10.14.1.1 password cisco
neighbor 10.45.1.5 remote-as 2500
neighbor 10.46.1.6 remote-as 2500
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R5
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 10.45.1.5 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 2500
no synchronization
neighbor 10.45.1.4 remote-as 2500
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R5
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 10.46.1.6 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 2500
no synchronization
neighbor 10.46.1.4 remote-as 2500
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
7 Replies 7
AxiomConsulting
Please can you post the routing table from the OSPF stub router?
PS - GNS3 - cool isnt it!
BB1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     172.16.0.0/24 is subnetted, 1 subnets
C       172.16.12.0 is directly connected, FastEthernet0/0
BB1#
Hello Ike,
as you see the routing table is empty with only the connected route in this condition it cannot ping anything
follow my suggestions in previous post to fix it
Hope to help
Giuseppe
AxiomConsulting
Sorry, was meant to add that there seems to be no redistribution of routes or default routes setup on any of the routers.
Cheers
Giuseppe Larosa
Hello Ike,
I would suggest to place the configurations on one or more txt files attached to the post to increase readibility
if you don't generate a default route in OSPF, or you don't redistribute the stub router can know nothing about BGP routes
also you are not advertising in BGP the OSPF routes with the network command
minimum set:
edge router generates a default route in OSPF with
router ospf
default-information originate always
router bgp
network for OSPF subnets
OR
router ospf
red bgp XX subnets
router bgp
network for ospf subnets
OR
router ospf
red bgp XX subnets
router bgp XX
red ospf yy
Hope to help
Giuseppe
Thanks. That was easy. I just have one question. How can I create a completed routing table without redistibtuing my internal OSPF routes in the BGP routing table? I mean how do I introduce the BGP routes in my OSPF table?
Hello Ike,
taking advantage of BGP network command that works not only for connected routes but also for all IP routes present in IP routing table
by redistributing BGP routes into OSPF but this is not used in real world because BGP usually carry much more IP prefixes then OSPF so the usual choice is to generate an OSPF default route on devices running both OSPF and BGP
Hope to help
Giuseppe
