OSPF conditional default-information originate
gustavoastorres
Greetings to all,
I looked everywhere for the answer, but couldn't find it. So, maybe someone in the forum can help me out.
We have 2 branches, each with its own Internet router and connected through a MPLS link.
In branch 1, we have a 2 Mbps Internet link (A). In branch 2, we have a 50 Mbps Internet link (B), plus a 2 (C) and 1 Mbps links (D).
Right now, all traffic for both branches comes and goes through B, but I'd like to change metrics in OSPF, so traffic from branch 1 would use A in case B goes down.
I tried to create a route map with different metric values set, depending on the matched output interface, and asociate it to the default-information originate and redistribute static statements, but had no result (or nasty ones).
Please, does anyone knows how to approach this problem?
Thank you all, and have a great afternoon.
Cheers,
Gustavo.
Hello Gustavo,
try adding a match ip address for the default route IPv4 prefix
like
ip prefix-list ONLY-DEFAULT permit 0.0.0.0/0
route-map GW permit 10
match ip address prefix ONLY-DEFAULT
match ip next-hop 10
set metric 1
route-map GW permit 20
set metric 50
The second block can be simplified as described above
The reason is that the ip next-hop is an attribute of an IP route so we need also to match on the prefix to be able to check the IP next hop.
Hope to help
Giuseppe
8 Replies 8
mvsheik123
Level 7
Level 7
Hi Gustavo,
Branch1 - how the default route towards 50Meg internet populated? It is via static route config (ip route 0.0.0.0 0.0.0.0 next hop)? If that is the case, you may want to look into 'IP SLA' traking feature. It worked perfect for me with static routes in place. Check the below link..
https://supportforums.cisco.com/docs/DOC-6078
hth
MS
Hi MS, thank you for your answer.
The default route to B is propagated through "default-information originate" in "router ospf", in router 2. In router 1, we have "default-information originate metric 50", so traffic flows to router 2.
IP SLA is good idea, but then I'd have to use it in other parts of the network. I was thinking of using OSPF with dynamic costs for default route.
Example for router 2:
router ospf 2
  default-information originate route-map DR
route-map DR permit 10
  match interface f0/0 <-- B
  set metric 1
route-map DR permit 20
  match interface f0/1 <-- C
  set metric 50
route-map DR permit 30
  match interface s0/0/0 <-- D
  set metric 60
But it seems the route-map is used only for matching, not setting.
Cheers,
Gustavo.
Hi Gustavo,
I guess OSPF conditional default route may help. Check this link.
http://packetlife.net/blog/2008/dec/12/ospf-conditional-default-route-injection/
hth
MS
Hello Gustavo,
I was able to do it successfully by matching on IP next-hop, in my case I was learning a default route from different eBGP sessions and I wanted like you to differentiate the seed metric depending on which eBGP neighbor = next-hop was providing the default route in BGP
under route-map use
access-list 11 permit host 192.168.1.1
route-map SET-SEED permit 10
match ip next-hop 11
set metric 1
route-map SET-SEED permit 20
match ip next-hop 12
set metric 20
You will need an access-list for each net-hop in each  route-map clause.
Hope to help
Giuseppe
Thank you for your response, Giuseppe.
Well, I tried it your way, but it seems OSPF doesn't handle it nicely. I create the following:
access-list 10 permit host 1.1.1.1 <-- s0/0/0 gateway
access-list 11 permit any <-- any other gateway
set metric 50
set metric 1
router ospf 2
default-info originate metric-type 1 route-map GW
The end result was no E1 LSA visible in neighboring routers for 0.0.0.0 from this router. (!!!)
Maybe I'm doing something wrong ...
Hello Gustavo,
like
set metric 1
set metric 50
Hope to help
Giuseppe
Hello Giuseppe,
You nailed it. Works like a charm.
Since I use a mix of DHCP-based and interface-based default routes, this is my final (partial) config for router 2:
router ospf 2
default-information originate metric-type 1 route-map DEFAULT
route-map DEFAULT permit 10
match ip address prefix-list ONLY-DEFAULT
match interface Serial0/0/0
set metric 11
route-map DEFAULT permit 15
match interface Dialer1
set metric 31
route-map DEFAULT permit 20
set metric 1
Thank you all very much for your help.
Hello Gustavo,
I have had the solution working for years in a mobile ISP backbone network, but it has been some years ago.
thanks for your kind rating
Best Regards
Giuseppe
