ospf config
iyappan_p
hi team,
we have a ospf ring for our cdma network,which happens to be switched network.we have formed the ring using 4 hsw switch card in cisco1841 router.Now we r experiencing ping delay to one of our site in the ring.as per the ospf config,if one of the site is down ,it takes the alternate path,that's fine.how to enable rstp in the router switch port.
expecting ur reply
royalblues
Level 10
Level 10
I dont think that the ether switch modules support RSTP. The faqs do not state it as a limitation but neither do they say it is supported
http://www.cisco.com/en/US/products/ps5855/products_qanda_item0900aecd8016c026.shtml
You can however configure the port a SPT portfast port
Narayan
The basic verification of layer 2 loop is to verify MAC address forwarding table. Check on what port each devices MAC are being learned.
