OSPF configuration
i am adding ospf configuration but don't know if i should use network command in router configuration or i have to enable ospf on the interface
(config)# router ospf 100
(config-router)# router-id 10.153.106.62
(config-router)# redistribute static subnets
(config-router)# redistribute connected subnets
(config-router)# passive-interface default
(config-router)# log-adjacency-changes
(config-router)# no discard-route
############# should i add network 10.153.106.0  0.0.0.255 area 0 or the interface configuration is enough  ############
(config)# interface Vlan 1
(config-if)# description *** OSPF Peering with router2***
 (config-if)# ip router ospf 100 area 0
(config-if)# no shutdown
(config-if)# no ip ospf passive-interface
Hello David
Looks okay to me and yes no need for network command -
Just remember to use : no passive interface xxx for any interface you would like to form an adjacency
Kind Regards
Paul
Hello
Its much better to apply ospf on the physical interface, it less prone to typos, it only activates ospf on that interface and in newer IOS , opsfv3  and nx-os its the only way.
Kind Regards
Paul
@paul driver
so paul my configuration is correct like that and no no need to add network command correct?
Hello David
Kind Regards
Paul
mkazam001
Level 3
Level 3
you can configure ospf in 2 ways here:
router ospf 100
or
int vlan 1
btw, if both these configs were on the same router, the interface config would be used
regards, mk
