OSPF Convergence time
Ibrahim Jamil
Level 6
Level 6
How to measure the time in ms when the fail over occur in ospf , time to converge from the primary to the secandery
thanks
5 Replies 5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Well, it depends on multiple factors.  Are you asking about convergence on just a single router or the whole network?  Are the primary and secondary on the same router or different routers, etc.?
I Have both scenario
Link on the Primary router and Link on the Secondary router
Link primary and Link secondary on the same router
thanks
Disclaimer
Posting
Ok, well on the router that the link failed, if it actually goes down, there's link debounce time, which varies, before the interface down is reported to the routing.  If the local interface doesn't go down, there's the OSPF dead time delay.
Then with Cisco's OSPF, and the IOS version, there's a configurable delay before an LSA is broadcast, there's a configurable delay before the receiving router will process the LSA, there's the time it takes to run SPF (which varies based on complexity of topology, speed of control plane processor, and options like iSPF), then there's the time for multiple routers to converge.  (NB: on some of Cisco timer's, there's additional configurable delay if there are multiple LSA within a certain amount of time.)
All of the above, together, might be under 100 ms to over 40 seconds.
PS:
With timer tuning, and fast detection of link outages, you might be able to achieve subsecond convergence.
Also if you have multiple equal cost paths, fail over can be in SONET time ranges.
Hi Joseph
thanks for your reply
Pls can you post me a docs related to the Below input from your end
thanks
Disclaimer
Posting
Search Cisco's main site for OSPF timers, specifically:
timers throttle spf
timers lsa arrival
timers throttle lsa
Also search for fast OSPF hellos and/or BFD.
