OSPF default route not redistributed back from BGP to OSPF
michaldieska
Hello community,
I have a little problem while playing with default route redistribution in my Hub and Spoke lab.
Please see topology bellow:
I would like to configure a default route on the London - HUB and this default route should be redistributed to spokes Manchester and Newcastle.
London - HUB config:
hostname LONDON
interface Loopback0
 ipv4 address 4.4.4.4 255.255.255.255
interface GigabitEthernet0/0/0/0
 ipv4 address 10.1.4.4 255.255.255.0
router ospf 1
 router-id 4.4.4.4
 default-information originate always
 area 0
  interface Loopback0
   passive enable
   network point-to-point
PE1 configuration:
vrf definition london
 rd 65001:1
 address-family ipv4
  route-target export 65001:1
  route-target import 65001:3
  route-target import 65001:2
 exit-address-family
vrf definition manchester
 rd 65001:3
 address-family ipv4
  route-target export 65001:3
  route-target import 65001:1
 exit-address-family
vrf definition newcastle
 rd 65001:2
 address-family ipv4
  route-target export 65001:2
 exit-address-family
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
 vrf forwarding london
 ip address 10.1.4.1 255.255.255.0
 ip ospf network point-to-point
interface GigabitEthernet0/1
 vrf forwarding newcastle
 ip address 10.1.2.1 255.255.255.0
interface GigabitEthernet0/2
 vrf forwarding manchester
 ip address 10.1.3.1 255.255.255.0
router ospf 1 vrf london
 router-id 1.1.1.1
 redistribute bgp 1 subnets
 network 10.1.4.0 0.0.0.255 area 0
router ospf 2 vrf newcastle
 network 10.1.2.0 0.0.0.255 area 0
router ospf 3 vrf manchester
 network 10.1.3.0 0.0.0.255 area 0
router bgp 1
 bgp log-neighbor-changes
 address-family ipv4 vrf london
  redistribute connected
  redistribute ospf 1 match internal external 1 external 2
 exit-address-family
 address-family ipv4 vrf manchester
  redistribute ospf 3 match internal external 1 external 2
 exit-address-family
 address-family ipv4 vrf newcastle
  redistribute ospf 2 match internal external 1 external 2
 exit-address-family
Manchester - SPOKE config:
interface Loopback0
 ip address 3.3.3.3 255.255.255.255
 ip ospf 1 area 0
 ip address 10.1.3.3 255.255.255.0
 ip ospf 1 area 0
router ospf 1
 router-id 3.3.3.3
 passive-interface Loopback0
Newcastle - SPOKE config:
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
 ip ospf 1 area 0
 ip address 10.1.2.2 255.255.255.0
 ip ospf 1 area 0
router ospf 1
 router-id 2.2.2.2
Now what I did:
1. Advertise the default route from HUB into OSPF and send it to the PE1 neighbor - this is working
PE1#show ip route vrf london
Routing Table: london
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 10.1.4.4 to network 0.0.0.0
O*E2  0.0.0.0/0 [110/1] via 10.1.4.4, 02:35:58, GigabitEthernet0/0
      2.0.0.0/32 is subnetted, 1 subnets
B        2.2.2.2 [20/2] via 10.1.2.2 (newcastle), 00:17:01, GigabitEthernet0/1
      3.0.0.0/32 is subnetted, 1 subnets
B        3.3.3.3
           [20/2] via 10.1.3.3 (manchester), 00:17:01, GigabitEthernet0/2
      4.0.0.0/32 is subnetted, 1 subnets
O        4.4.4.4 [110/2] via 10.1.4.4, 02:37:11, GigabitEthernet0/0
      10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
B        10.1.2.0/24 is directly connected, 00:17:01, GigabitEthernet0/1
L        10.1.2.1/32 is directly connected, GigabitEthernet0/1
B        10.1.3.0/24 is directly connected, 00:17:01, GigabitEthernet0/2
L        10.1.3.1/32 is directly connected, GigabitEthernet0/2
C        10.1.4.0/24 is directly connected, GigabitEthernet0/0
L        10.1.4.1/32 is directly connected, GigabitEthernet0/0
2. Redistribute this route into BGP and create a VPNv4 prefix (with RT=65001:1) - this is also working:
PE1#show bgp vpnv4 uni vrf london 0.0.0.0
BGP routing table entry for 65001:1:0.0.0.0/0, version 2
Paths: (1 available, best #1, table london)
  Not advertised to any peer
  Refresh Epoch 1
  Local
    10.1.4.4 (via vrf london) from 0.0.0.0 (1.1.1.1)
      Origin incomplete, metric 1, localpref 100, weight 32768, valid, sourced, best
      Extended Community: RT:65001:1 OSPF DOMAIN ID:0x0005:0x000000010200
        OSPF RT:0.0.0.0:5:1 OSPF ROUTER ID:1.1.1.1:0
      rx pathid: 0, tx pathid: 0x0
3. Now import this route into VRF Manchester as well as Newcastle - also working:
PE1#show ip route vrf manchester 0.0.0.0
Routing Table: manchester
Routing entry for 0.0.0.0/0, supernet
  Known via "bgp 1", distance 20, metric 1, candidate default path, type external
  Redistributing via ospf 3
  Last update from 10.1.4.4 on GigabitEthernet0/0, 00:19:34 ago
  Routing Descriptor Blocks:
  * 10.1.4.4 (london), from 0.0.0.0, 00:19:34 ago, via GigabitEthernet0/0
      Route metric is 1, traffic share count is 1
      AS Hops 0
      MPLS label: none
PE1#show ip route vrf newcastle 0.0.0.0
Routing Table: newcastle
  Redistributing via ospf 2
  Last update from 10.1.4.4 on GigabitEthernet0/0, 00:19:55 ago
  * 10.1.4.4 (london), from 0.0.0.0, 00:19:55 ago, via GigabitEthernet0/0
      AS Hops 0
      MPLS label: none
4. Import this default route into the OSPF database and sent it to OSPF peers Manchester and Newcastle - this is not working:
PE1#show ip ospf database
            OSPF Router with ID (10.1.3.1) (Process ID 3)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
3.3.3.3         3.3.3.3         1457        0x80000007 0x0001B8 3
10.1.3.1        10.1.3.1        1476        0x80000007 0x00587A 2
                Type-5 AS External Link States
Link ID         ADV Router      Age         Seq#       Checksum Tag
4.4.4.4         10.1.3.1        1266        0x80000001 0x00C37D 3489660929
10.1.4.0        10.1.3.1        1266        0x80000001 0x00B78B 3489660929
            OSPF Router with ID (10.1.2.1) (Process ID 2)
2.2.2.2         2.2.2.2         1430        0x80000007 0x00C108 3
10.1.2.1        10.1.2.1        1453        0x80000007 0x0026B4 2
4.4.4.4         10.1.2.1        1266        0x80000001 0x00CA77 3489660929
10.1.4.0        10.1.2.1        1266        0x80000001 0x00BE85 3489660929
            OSPF Router with ID (1.1.1.1) (Process ID 1)
1.1.1.1         1.1.1.1         1691        0x80000008 0x00855C 2
4.4.4.4         4.4.4.4         1608        0x80000008 0x005959 3
0.0.0.0         4.4.4.4         1608        0x80000005 0x00BAE3 1
2.2.2.2         1.1.1.1         1266        0x80000001 0x007FD4 3489660929
3.3.3.3         1.1.1.1         1266        0x80000001 0x0051FE 3489660929
10.1.2.0        1.1.1.1         1266        0x80000001 0x002D23 3489660929
10.1.3.0        1.1.1.1         1266        0x80000001 0x00222D 3489660929
Just to confirm there is no OSPF default route in the SPOKEs RIBs:
Routing table on Manchester - no default route:
Manchester#show ip route
Gateway of last resort is not set
C        3.3.3.3 is directly connected, Loopback0
O E2     4.4.4.4 [110/2] via 10.1.3.1, 00:22:32, GigabitEthernet0/2
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.1.3.0/24 is directly connected, GigabitEthernet0/2
L        10.1.3.3/32 is directly connected, GigabitEthernet0/2
O E2     10.1.4.0/24 [110/1] via 10.1.3.1, 00:22:32, GigabitEthernet0/2
Routing table on Newcastle- no default route:
Necastle#show ip route
C        2.2.2.2 is directly connected, Loopback0
O E2     4.4.4.4 [110/2] via 10.1.2.1, 00:22:26, GigabitEthernet0/1
C        10.1.2.0/24 is directly connected, GigabitEthernet0/1
L        10.1.2.2/32 is directly connected, GigabitEthernet0/1
O E2     10.1.4.0/24 [110/1] via 10.1.2.1, 00:22:26, GigabitEthernet0/1
So I have 2 questions:
1 - In order to redistribute the default route from OSPF to BGP, do I really need to create the "redistribute" as well as "default-information originate" statements?
2 - Why there is no default route on spokes :(
Much appreciated your help guys.
Thank you.
Harold Ritter
redistribute
as well as
statements?
Yes, you need the
to allow redistribution of the default route into BGP. Both commands are needed.
You cannot redistribute the default route into OSPF. You need to use the
to achieve that.
Harold Ritter
redistribute
as well as
statements?
Yes, you need the
to achieve that.
Thank you very much Harold, I knew I am missing something simple :)
Have a nice day.
