OSPF Design Question
kevin.hu
Level 3
Level 3
There are two data centers at opposite side of the coast. A spoke router near Data Center 1 has two WAN links and connect to each ABRs at Data Center 1.
For redundancy purpose, a third WAN link is installed and connected to Data Center 2.
My question is, how would you design your area so that if Data Center 1 fails, a spoke router will fail over to Data Center 2? Group all 3 links into one Area or Group 2 links to one Area and the third link to its own area?
Thanks for your help!
Thanks.
Mohamed Sobair
Level 7
Level 7
Hi Kevin,
Group the 2 Wan links connects DC1 to the same Area.
The 3rd link would be in seperate area.
You dont need the 3 links to be in one area since the 3rd wan link used as backup.
Mohamed
