OSPF Designated Router
UncleJP
I was studying OSPF, and I had a thought. Is there ALWAYS a DR and BDR in an OSPF network?
Any feedback is appreciated.
Scott Leport
Level 7
Level 7
Not always.
You can enable "ip ospf network point-to-point" on your interface configuration to effectively turn off the DR and BDR election process.
As the name suggests, it's typically used when there are only two routers on either end of a link.
Otherwise yes there is a DR / BDR relationship in an OSPF network, but you can influence what your DR / BDR routers are.
There are a LOT of resources out there, online and books which reference the DR / BDR election process and the various scenarios.
Good luck
Scott Leport
Level 7
Level 7
Not always.
Good luck
Martin L
For exam you might want to memorize following tables (from very old Route CCNP book by D.Teare, CiscoPress)
