OSPF (DR and BDR)
wolniqking1
Hey Everyone,
I got a doubt as we were part of the discussion with my techie guys.
Question: Can we configure OSPF without DR and BDR?
Thank You,
RSJ
Yes , OSPF can be configured without DR, BDR .
DR, BDR election depends on the type of OSPF network that is configured , For eg:
1)  On a serial link  by default OSPF network type is Point to Point , and in this no DR, BDR election takes place .
2) While on an ethernet link the default OSPF network type is Broadcast(Used in Full mesh Topology )   , and in this DR , BDR election will be done .
- Similarly there are Point to Multipoint & P2MP Non Broadcast OSPF network types (Used in Hub & Spoke Topology )  , for them also no DR, BDR election will take place .
Spooster IT Services Team
Hello
Yes you can, it depends on what ospf network type is chosen that will stiipulate if DR /BDR election take place.
Those valid ospf network types are:
Non-Broadcast
Broadcast
Kind Regards
Paul
Joseph W. Doherty
I believe the answer is yes, as also described by the other posters.
The reason I "believe" is because I know you can use p2p on broadcast medium for a pair of OSPF routers (and it's done to slightly increase efficiency).  However, if you have more than two OSPF routers sharing a subnet, on broadcast medium, I believe point to multi-point (also mentioned by @Spooster IT Services ) could be used instead; however it wouldn't be quite as efficient and/or recover if the "hub" router fails, I believe.
why you think that OSPF need DR/BDR to work ??
