05-10-2024 07:47 AM - edited 05-10-2024 10:11 AM
Hi everyone,
I have 2 Aruba GWs and 2 L3 cisco switches with their respective VLANs and Network subnets.
Both GWs are active and each cisco forwards traffic to it's respective GW.
I want to achieve a dynamic traffic failover (ospf) if one of the GWs would fail.
Although cisco boxes can ping cross vlans using ospf (409/500) they cannot ping the far end GW's IP. So SW1 cannot ping 10.2.6.2 and SW2 cannot ping 10.2.2.1
any ideas?
Aruba GW --- cisco -- to -- cisco ---- Aruba GW
SW1
interface Vlan55
ip address 10.2.4.2 255.255.255.0
ip ospf message-digest-key 5 md5 xxxx
interface Vlan500
ip address 10.2.2.63 255.255.254.0
router ospf 1
router-id 10.2.4.2
area 5 authentication message-digest
redistribute static
redistribute connected
network 10.2.4.0 0.0.0.255 area 5
network 10.2.2.0 0.0.1.255 area 5
default-information originate
ip route 0.0.0.0 0.0.0.0 10.2.2.1
i-------------
SW2
interface Vlan55
ip address 10.2.4.1 255.255.255.0
interface Vlan409
ip address 10.2.6.61 255.255.254.0
router ospf 1
router-id 10.2.4.1
redistribute static
network 10.2.6.0 0.0.1.255 area 5
ip route 0.0.0.0 0.0.0.0 10.2.6.2
SW1(config)#do ping 10.2.6.2 <<<<< ----- I cannot ping the gateways on each side!
Sending 5, 100-byte ICMP Echos to 10.2.6.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
SW1(config)#do ping 10.2.6.61 <<<<< ----- !
Sending 5, 100-byte ICMP Echos to 10.2.6.61, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
05-10-2024 07:56 AM
Can you draw topolgy
Also both Aruba GW have same subnet ?
MHM
05-10-2024 08:05 AM
Hi thanks for the response.
topology
Topology
Aruba GW [10.2.2.2 --vlan409-- 10.2.2.61] cisco [vlan55 10.2.4.2 ospf vlan55 10.2.4.1] cisco [10.2.6.63 --vlan500-- 10.2.6.2] Aruba GW
Arubas are on different segments.
05-10-2024 08:15 AM
show ip route
show ip ospf neighbor
show ip ospf interface brief
share this for both SW
MHM
05-10-2024 08:25 AM
SW1#show ip route
Gateway of last resort is 10.2.2.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.2.2.1
10.0.0.0/8 is variably subnetted, 5 subnets, 3 masks
C 10.2.2.0/23 is directly connected, Vlan500
L 10.2.2.63/32 is directly connected, Vlan500
C 10.2.4.0/24 is directly connected, Vlan5
L 10.2.4.2/32 is directly connected, Vlan5
O 10.2.6.0/23 [110/2] via 10.2.4.1, 00:06:23, Vlan5
SW1#show ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
10.2.4.1 1 FULL/BDR 00:00:35 10.2.4.1 Vlan5
SW1#show ip ospf interface brief
Interface PID Area IP Address/Mask Cost State Nbrs F/C
Vl500 1 5 10.2.2.63/23 1 DR 0/0
Vl5 1 5 10.2.4.2/24 1 DR 1/1
SW2#sh ip route
Gateway of last resort is 10.2.6.2 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.2.6.2
O 10.2.2.0/23 [110/2] via 10.2.4.2, 00:08:27, Vlan5
L 10.2.4.1/32 is directly connected, Vlan5
C 10.2.6.0/23 is directly connected, Vlan409
L 10.2.6.61/32 is directly connected, Vlan409
SW2#show ip ospf neighbor
10.2.4.2 1 FULL/DR 00:00:35 10.2.4.2 Vlan5
SW2#show ip ospf interface brief
Vl409 1 5 10.2.6.61/23 1 DR 0/0
Vl5 1 5 10.2.4.1/24 1 BDR 1/1
05-14-2024 01:48 AM
Hello @Paco-Paco ,
comparing show ip ospf neig and show ip ospf interface on both SW1 and SW2 we can see that Sw1 has no neighbor on SVI Vlan 500 and SW2 has no neighbor on SVI VLAN 409.
As a result of this the Aruba devices do not take part in the OSPF routing domain in area 5 and this is why you cannot ping a remote Aruba device.
Check the MTU, the IP subnet mask and the area ID you may need to use area ID 0.0.0.5 on the Aruba.
Also as @Georg Pauwen has noted why are you attempting to inject a default route in OSPF on both SW1 and SW2 ?
Hope to help
Giuseppe
05-10-2024 08:17 AM - edited 05-10-2024 09:23 AM
<cut>
05-13-2024 11:19 PM
Sorry I dont see last reply
MHM
05-14-2024 01:36 AM
why are you originating the default route on both Cisco switches ? Can you post a schematic drawing showing how your devices are physically and logicall;y connected (including the OSPF areas) ? Are the Aruba gateways running OSPF as well ?
Also post the full configs of the Cisco and the Aruba devices...
