OSPF Equal Load Balancing Not Working
Hi All,
I am having trouble with equal cost load balancing.
I am trying to ping host with IP 10.0.10.11
Below are the routers that I am trying to loadbalance. But almost all off traffic is going out Ethernet0/1 only even though they are with equal cost.
And this is the output of the route table
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
O 10.0.0.0/30 [110/20] via 84.0.1.1, 00:04:50, Ethernet0/1
[110/20] via 52.0.1.1, 00:04:50, Ethernet0/0
O 10.0.0.4/30 [110/20] via 84.0.1.1, 00:04:50, Ethernet0/1
O 10.0.0.8/30 [110/30] via 84.0.1.1, 00:04:50, Ethernet0/1
[110/30] via 52.0.1.1, 00:04:50, Ethernet0/0
O 10.0.10.0/24 [110/30] via 84.0.1.1, 00:04:50, Ethernet0/1
O 10.0.20.0/24 [110/30] via 84.0.1.1, 00:04:50, Ethernet0/1
11 Replies 11
mohammed01701
Hi!
Could you post configs on both routers?
/Mohammed
Router 1:
Current configuration : 2218 bytes
version 15.2
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
redundancy
interface Ethernet0/0
ip address 52.0.1.1 255.255.255.252
interface Ethernet0/1
ip address 84.0.1.1 255.255.255.252
interface Ethernet0/2
ip address 10.0.0.1 255.255.255.252
interface Ethernet0/3
ip address 10.0.0.5 255.255.255.252
interface Ethernet1/0
ip address 172.16.10.1 255.255.255.0
interface Ethernet1/1
no ip address
shutdown
interface Ethernet1/2
no ip address
shutdown
interface Ethernet1/3
no ip address
shutdown
interface Ethernet2/0
no ip address
shutdown
interface Ethernet2/1
no ip address
shutdown
interface Ethernet2/2
no ip address
shutdown
interface Ethernet2/3
no ip address
shutdown
interface Ethernet3/0
no ip address
shutdown
interface Ethernet3/1
no ip address
shutdown
interface Ethernet3/2
no ip address
shutdown
interface Ethernet3/3
no ip address
shutdown
interface Serial4/0
no ip address
shutdown
serial restart-delay 0
interface Serial4/1
no ip address
shutdown
interface Serial4/2
no ip address
shutdown
interface Serial4/3
no ip address
shutdown
interface Serial5/0
no ip address
shutdown
interface Serial5/1
no ip address
shutdown
interface Serial5/2
no ip address
shutdown
interface Serial5/3
no ip address
shutdown
router ospf 10
router-id 1.1.1.1
network 10.0.0.0 0.0.0.3 area 0
network 10.0.0.4 0.0.0.3 area 0
network 52.0.1.0 0.0.0.3 area 0
network 84.0.1.0 0.0.0.3 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
snmp-server community network RW
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
Router 2:
Current configuration : 2230 bytes
version 15.2
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
ip address 52.0.1.2 255.255.255.252
ip address 84.0.1.2 255.255.255.252
ip address 192.168.0.1 255.255.255.252
ip address 192.168.0.5 255.255.255.252
ip address 172.16.10.2 255.255.255.0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Serial4/0
no ip address
shutdown
interface Serial4/1
no ip address
shutdown
interface Serial4/2
no ip address
shutdown
interface Serial4/3
no ip address
shutdown
interface Serial5/0
no ip address
shutdown
interface Serial5/1
no ip address
shutdown
interface Serial5/2
no ip address
shutdown
interface Serial5/3
no ip address
shutdown
router ospf 10
router-id 2.2.2.2
network 192.168.0.0 0.0.0.3 area 0
network 192.168.0.4 0.0.0.3 area 0
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
with ip cef enabled, the default load sharing algorithm is per destination. You can change that with the interface command 'ip load-sharing per-packet'. Try and configure this on all participating interfaces...
Router 1:
version 15.2
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Serial4/0
no ip address
shutdown
interface Serial4/1
no ip address
shutdown
interface Serial4/2
no ip address
shutdown
interface Serial4/3
no ip address
shutdown
interface Serial5/0
no ip address
shutdown
interface Serial5/1
no ip address
shutdown
interface Serial5/2
no ip address
shutdown
interface Serial5/3
no ip address
shutdown
router ospf 10
router-id 1.1.1.1
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
Router 2:
version 15.2
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Serial4/0
no ip address
shutdown
interface Serial4/1
no ip address
shutdown
interface Serial4/2
no ip address
shutdown
interface Serial4/3
no ip address
shutdown
interface Serial5/0
no ip address
shutdown
interface Serial5/1
no ip address
shutdown
interface Serial5/2
no ip address
shutdown
interface Serial5/3
no ip address
shutdown
router ospf 10
router-id 2.2.2.2
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
omz
But there are already 2 path in the routing table..
Now to see if the cef is enabled? And if its not, how can enable it ?
Hi!
Run command "show ip cef" and see if you cef is enabled. You can enable cef by going on config terminal and then run command "ip cef"
/Mohammed
Router1# show ip cef
Prefix Next Hop Interface
0.0.0.0/0 no route
0.0.0.0/8 drop
0.0.0.0/32 receive
10.0.0.0/30 attached Ethernet0/2
10.0.0.0/32 receive Ethernet0/2
10.0.0.1/32 receive Ethernet0/2
10.0.0.2/32 attached Ethernet0/2
10.0.0.3/32 receive Ethernet0/2
10.0.0.4/30 attached Ethernet0/3
10.0.0.4/32 receive Ethernet0/3
10.0.0.5/32 receive Ethernet0/3
10.0.0.6/32 attached Ethernet0/3
10.0.0.7/32 receive Ethernet0/3
10.0.0.8/30 10.0.0.2 Ethernet0/2
10.0.0.6 Ethernet0/3
10.0.10.0/24 10.0.0.2 Ethernet0/2
10.0.20.0/24 10.0.0.6 Ethernet0/3
52.0.1.0/30 attached Ethernet0/0
52.0.1.0/32 receive Ethernet0/0
52.0.1.1/32 receive Ethernet0/0
52.0.1.2/32 attached Ethernet0/0
This is the output of the command.
Hi!
Can you post "show ip ospf nei"? Where have you 10.0.10.0/24 is that network behind R1 och R2?
/Mohammed
Its behind R1.
Router1#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
2.2.2.2 1 2WAY/DROTHER 00:00:37 84.0.1.2 Ethernet0/1
2.2.2.2 1 2WAY/DROTHER 00:00:36 52.0.1.2 Ethernet0/0
4.4.4.4 1 2WAY/DROTHER 00:00:36 10.0.0.6 Ethernet0/3
3.3.3.3 1 2WAY/DROTHER 00:00:37 10.0.0.2 Ethernet0/2
Router2#sh ip ospf neighbor
6.6.6.6 1 FULL/DR 00:00:35 192.168.0.6 Ethernet0/3
5.5.5.5 1 FULL/DR 00:00:34 192.168.0.2 Ethernet0/2
1.1.1.1 1 FULL/BDR 00:00:36 84.0.1.1 Ethernet0/1
1.1.1.1 1 FULL/BDR 00:00:38 52.0.1.1 Ethernet0/0
Hi!
Can you post "show ip route on R1"? It has to be like this output:
Router1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.0.0.0/30 is directly connected, Ethernet0/2
L 10.0.0.1/32 is directly connected, Ethernet0/2
C 10.0.0.4/30 is directly connected, Ethernet0/3
L 10.0.0.5/32 is directly connected, Ethernet0/3
52.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 52.0.1.0/30 is directly connected, Ethernet0/0
L 52.0.1.1/32 is directly connected, Ethernet0/0
84.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 84.0.1.0/30 is directly connected, Ethernet0/1
L 84.0.1.1/32 is directly connected, Ethernet0/1
192.168.0.0/30 is subnetted, 2 subnets
O 192.168.0.0 [110/20] via 84.0.1.2, 00:03:09, Ethernet0/1
[110/20] via 52.0.1.2, 00:03:19, Ethernet0/0
O 192.168.0.4 [110/20] via 84.0.1.2, 00:03:09, Ethernet0/1
