OSPF equivalent of EIGRP Leak-map
enrique jehanno
I'm looking for an equivalent of the EIGRP leak-map with OSPF.
Have you already seen this kind of configuration ?
5 Replies 5
daniel.dib
Level 7
Level 7
What are you trying to do?
EIGRP is distance vector and OSPF is link state so the same tools can't be used. Explain what you are after and we'll try to help you out. Do you mean to do a summary on ABR but still leak some prefixes within the summary?
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Thank you for your help.
As you said, I'm trying to announce a specific route and a summary which already include this specific route (on an ASBR).
Kindly try if the below helps to achieve what you want to do.
summary-address {{ip-address mask} | {prefix mask}} [not-advertise] [tag tag]
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfospf.html#wp1029504
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
In fact, one of my colleague has found a solution (thanks!).
Using the diagram above, I would like summarized a 10.1.0.0/22 and also announced the specific 10.1.1.0/24.
The following configuration can be used:
R1:
router ospf 1
router-id 1.1.1.1
summary-address 10.1.0.0 255.255.252.0
summary-address 10.1.1.0 255.255.255.0
redistribute connected subnets
network 192.168.1.0 0.0.0.255 area 0
On R2, we can see:
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
O E2     10.1.0.0/22 [110/20] via 192.168.1.1, 00:05:48, FastEthernet0/1
O E2     10.1.1.0/24 [110/20] via 192.168.1.1, 00:00:07, FastEthernet0/1
Nice.
I was going to suggest that you tried to play with distribute-list and area range command on ABR but you found a better solution.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
