OSPF exstart state
rajaajmer
When my primary link goes down, ISDN Ospf neighbourship is going to exstart state.
Rtr BL----
interface Dialer1
ip address XXX XXX
no ip redirects
encapsulation ppp
ip route-cache flow
load-interval 30
dialer pool 1
dialer remote-name m
dialer idle-timeout 300
dialer string XXXXX
dialer string XXXXX
dialer string XXXXX
dialer load-threshold 78 either
dialer-group 1
no cdp enable
ppp authentication chap
ppp multilink
end
Router MC
interface Dialer1
description xXX
ip address XXXX XXXXXX
no ip redirects
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer in-band
dialer map ip XXXX name BL broadcast XXXXXX
dialer load-threshold 25 either
dialer-group 1
no fair-queue
no cdp enable
ppp multilink
end
both the interface ip's are allowed in OSPF.
What could be the reason for not establishing the full state in OSPF? pls advice
17 Replies 17
rajaajmer
please advice.
Please go through this document
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0d.shtml
HTH, Please rate if it does
Pavan
i have checked the MTU size , its 1500 on both router (dialer) interface.
mohammedmahmoud
Level 11
Level 11
Can you please send "show ip ospf neighbor", and the OSPF process configuration on both routers.
BR,
Mohammed Mahmoud.
This is while the issue was happening.
sh ip ospf nei
Neighbor ID Pri State Dead Time Address Interface
172.241.247.47 1 FULL/BDR 00:00:36 170.241.247.250 FastEthernet0/1
172.241.247.46 1 FULL/BDR 00:00:39 170.241.247.246 FastEthernet0/0
172.241.242.189 1 EXSTART/ - 00:00:39 170.241.247.69 Dialer1
The problem is most frequently caused by the inability to successfully exchange DBD packets which many be due to neighbor between PRI and BRI/dialer, let me check it and get back to you.
HTH,
Mohammed Mahmoud.
I had faced a similar situation (not with an ISDN interafce though) where we chnaged the module and the symptom got rectified.
Can you try establishing the adjaceny over the ISDN interface without configuring it as backup for the primary?
Narayan
simulating it,at this point of time will not be possible. but wanted to know the there can be some other reason other than MTU , which will make the state of OSPF to EXSTART
Please check this out:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0d.shtml#solution
P.S: I'll be testing the BRI/PRI issue and i'll get back to you.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
thx. looking forward for testing results.
hi Mohammed ,
Any results from the testing ?
Can somebody help me getting the reason for my probelm please ?
Sarosh,
Have you tried running a "show ip ospf adj" on these two routers? This would give you a good hint of what the issue is.
Hope this helps,
I would also try setting a "dialer map ip broadcast" on either side. Currently, only router MC is configured this way.
Hope this helps,
