OSPF filtering Not working
Alex Samad
I have 2 cisco switches acting as ospf routers.
they have 1 leg in area 0 the back bone and in area 10.172.0.0 (nssa) via 6 connected vlan interfaces.
I also have 2 more ospf routers, that also talk BGP to a 3rd party and redistribute the routes from BGP back into OSPF for area 10.172.0.0
I want to stop any non 10.172.0.0 routes leaving area 10.172.0.0 and making their way into area 0
I have tried to follow this http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080531fd2.shtml#prefixadmin  with the route-map tag, but it didn't work
!! in list into router ospf 2 from ospf 1
no route-map filter_ospf1
route-map filter_ospf1 deny 10
match tag 1
route-map filter_ospf1 permit 20
ip prefix-list FilterOut seq 10 permit 10.172.0.0/16 le 32
!! in list into router ospf 1 from ospf 2
no route-map filter_ospf2
route-map filter_ospf2 deny 10
match tag 2
route-map filter_ospf2 permit 20
match ip  address prefix-list FilterOut
route-map filter_ospf2 deny 30
no router ospf 1
no router ospf 2
router ospf 1
router-id 10.31.19.253
log-adjacency-changes
area 0.0.0.0 authentication message-digest
network 10.31.19.0 0.0.0.255 area 0.0.0.0
redistribute ospf 2 subnet tag 1
distribute-list route-map filter_ospf2 in
router ospf 2
router-id 10.172.255.2
area 10.172.0.0 authentication message-digest
area 10.172.0.0 range 10.172.0.0 255.255.0.0 advertise
network 10.172.201.0 0.0.0.255 area 10.172.0.0
network 10.172.202.0 0.0.0.255 area 10.172.0.0
network 10.172.203.0 0.0.0.255 area 10.172.0.0
network 10.172.204.0 0.0.0.255 area 10.172.0.0
network 10.172.205.0 0.0.0.255 area 10.172.0.0
network 10.172.207.0 0.0.0.255 area 10.172.0.0
network 10.172.208.0 0.0.0.255 area 10.172.0.0
network 10.172.212.0 0.0.0.255 area 10.172.0.0
network 10.172.213.0 0.0.0.255 area 10.172.0.0
network 10.172.250.0 0.0.0.255 area 10.172.0.0
network 10.172.255.2 0.0.0.0 area 10.172.0.0
redistribute ospf 1 subnet tag 2
distribute-list route-map filter_ospf1 in
I also tried
no router ospf 1
no router ospf 2
no ip prefix-list FilterOut
!!ip prefix-list FilterOut seq 10 permit 10.172.0.0/16 le 32
router ospf 1
!!area 0.0.0.0 filter-list prefix FilterOut in
area 10.172.0.0 nssa
area 10.172.0.0 filter-list prefix FilterOut out
redistribute connected subnets
again didn't work ...  when i check other routers on area 0 they have all the non 10.172.0.0/24 address
thanks
3 Accepted Solutions
Rolf Fischer
Level 9
Level 9
Hi Alex,
maybe there is a easier and better (more robust) solution.
If my understanding is correct, you have 2 NSSASBRs that inject BGP prefixes into the NSSA and you want to keep those external prefixes only within the NSSA?
If so, you could use the nssa-only option:
area nssa [nssa-only]
I have to admit that I didn't try it so far but avoiding the 7-to-5 translation at the NSSABRs sounds like the perfect solution. A robust OSPF-to-OSPF redistribution with more than one redistribution point can really be a challenge, I personally would consider it as a last-resort.
Rolf
[EDIT]: I noticed that the nssa-only keywork was fisrt added in 15.0(1)M, so it may no be applicable on your routers.
Sorry for the delay, I really had to think for a while what I would do to solve that.
Actually, your first attempt wasn't bad at all, and I'd try to do some modifications:
1. Basic config to avoid loops between the 2 processes when redistributing:
match tag 1
match tag 2
router ospf 1 ! Area 0
! (redistribute ospf 2 subnet tag 1)
router ospf 2 ! Area 10.172.0.0
2. So far, so good. Now we'll need an extra route-map to filter out the unwanted routes when redistributing the NSSA-Routes into Area 0:
route-map 10_172_ONLY permit 10
redistribute ospf 2 subnet route-map 10_172_ONLY tag 1 ! don't forget the tag!
Unfortunately I couldn't test it but I think it should work.
Rolf
but all the directly attached ones are not there.
I have tried redistribute connected in router ospf 2 but that didn't help.
Is OSPF enabled on the IP-interfaces of those connected networks (show ip ospf interface )?
If they belong to OSPF 2 and you want to redistribute them to OSPF 1 too, are they in the range 10.172/16 (route-map 10_172_ONLY)?
11 Replies 11
Rolf Fischer
Level 9
Level 9
Hi Alex,
Rolf
Alex,
I re-read the config-parts in your posting and have two more annotations:
1. The "Filtering routes based on tags" section in the document you linked is an example how to aviod routing loops when redistribute between two OSPF processes. It is not used to filtering in terms of redistribute only certain prefixes.
2. The area filter-list command only works for Type-3 LSAs. The flooding scope of external routes is AS-wide and you cannot filter Type-5 LSAs with the area filter-list command.
What would work for filtering out external prefixes is the distribute-list in command. You can define which prefixes from one process will be installed in the local routing table and only those routes will be redistributed into the other process.
But like mentioned in my first posting, I wouldn't recommend to do so. The document you linked describes the problems you can run into and how to solve them; so I'd watch for another solution, if possible. What about another routing protocol (e.g. EIGRP) for distributing the BGP prefixes within the NSSA?
Best regards
Rolf
Firstly the cisco switches are
WS-C3560G-24PS     12.2(53)SE            C3560-IPSERVICESK9-M
area nssa [nssa-only] doesn't seem to be available for me.  But I believe your assesment in the first reply is correct
area 0
area 1  + 2 bgp routers injecting routes in to the nssa
the aim is to keep those routes out of area 0 and any other area !
"Filtering routes based on tags"  i thought this also included a section on how to filter out unwanted routes
To quote from there
There can be several reasons for redistribution between multiple processes. These are a few examples:
  • To filter an OSPF route from part of the domain
  • To separate different OSPF domains
  • To migrate between separate domains
the first option is what I am after, I believe that when I create my route-map not only can I add in my deny tag, but I should be able to have a allow prefix filter... and then deny the rest !
as for using eigrp I have other devices that don't do eigrp
I guess the other option i could do is add more to its distance/metric for specific routes
the other problem with this is that router is the dgw for a lot of machines that need access to those routes ...
Alex,
of course you can filter out unwanted routes between two OSPF processes based on tags, but this is not what the document describes. The document deals with making the OSPF-to-OSPF redistribution more robust, since you can run into some very special problems when implementing this.
You could tag the BGP routes when redistributing them into OSPF and filter based on those tags (deny them).
But again, you'll have to add some configuration in order to achieve a stable and predictable solution.
We also use OSPF as IGP and once in a while we have to redistribute beween OSPF processes too (but regular areas) because we have to interconnect OSPF routers outside our administrative domain. We experienced some of the problems described in the document (like routing loops; something you don't expect when using a link-state routing protocol), that's why I'm emphazising that.
I think it would really help if you could provide a simple network diagram only with the relevant part including the router/switch-platforms, areas and router roles.
Rolf
hope that helps the cut out in the bottom right is inside office, there are multiple vlans and the dgw is the 2 OSPF routers, using hsrp (the cisco's can't be stacked so I have to use HSRP).  the man is the backbone and I am in the process of bringing up dc2... so I am testing ospf between the office routers and the dc2 routers.  so its the dc2 routers I can check whats been publish as well as looking on the office routers.
the 3rd party has connetions at each of the locations. the office one is only very small pipe compared to all the other connection and would rather have the connection die then fall back over the office one. But we need the office one for office stuff !
I am thinking I might just run 2 opsf processes and publish 10.172.0.0 as a summerised network out to the backbone and not do anything dynamic from area 10.172.0.0 into the rest of the network ..
but now its a challenge to see if I can get it working.
So the other reason to do the filtering is if I attach anything else into office I don't want the routers flowing in to the DC's
match tag 1
match tag 2
Rolf
Thanks looks like I am nearly there
this is what i used
no ip prefix-list FilterOut seq 10
no route-map 10_172_ONLY
match tag 1
match tag 2
no router ospf 1
router ospf 1
redistribute ospf 2 subnets tag 1 route-map 10_172_ONLY
no router ospf 2
router ospf 2
redistribute ospf 1 subnets tag 2
problem !
sh ip ospf 1 database only shows me
10.172.209.0    10.31.19.252    15          0x80000001 0x003AAC 1
10.172.209.0    10.31.19.253    34          0x80000001 0x0034B1 1
10.172.255.2    10.31.19.252    15          0x80000001 0x00CFEF 1
10.172.255.3    10.31.19.253    34          0x80000001 0x00BFFD 1
10.172.255.6    10.31.19.252    15          0x80000001 0x0002B0 1
10.172.255.6    10.31.19.253    34          0x80000001 0x00FBB5 1
10.172.255.7    10.31.19.252    15          0x80000001 0x00F7B9 1
10.172.255.7    10.31.19.253    34          0x80000001 0x00F1BE 1
so .6 .7 .2 .3 are routerid, 209 is the network not directly attached to this switch, but all the directly attached ones are not there
I have tried redistribute connected in router ospf 2 but that didn't help ..
No they are not, should I have an entry in the interface for them
so i was reading that there is 2 ways to do it.
1) with the network commen in the router ospf statement
or
2) ip ospf in the interface definition
I think 2 is the prefered way yes ?
OKay, so I applied the configuration to each interface and remove the network command from the router ospf 2 config
then i added in a
to ospf 1
and now only the summary address is being broadcast back to the backbone
I re entered the network statements in ospf2 and it worked so !
