mpls ldp neighbour targeted hello not showing recv
One of our ldp neighbour in the router not showing recv in targeted hello in one end
ospf neighbour is up, ldp neighbour is up
sh mpls ldp discovery
Local LDP Identifier:
    172.16.26.28:0
    Discovery Sources:
    Interfaces:
GigabitEthernet2/18.1512 (ldp): xmit/recv
            LDP Id: 172.16.26.74:0
    172.16.26.28:0
    Discovery Sources:
    Interfaces:
Targeted Hellos:
172.16.26.28 -> 172.16.26.74 (ldp): active, xmit
no password config is present
mpls ldp router-id Loopback force command is present
no access list configured on this neighbour
mpls ip & global ldp is configured on that interface
both the router having multiple other link & all that link having no issue except the above
both side is pingable
only problemativ side no showing "recv" , but remote end showing "xmit/recv"
Pls suggest further
subhojit
5 Replies 5
Harold Ritter
Hi Subhojit,
What is the targeted ldp session used for; Eompls, LDP over MPLS TE, LDP session protection? It looks like one side is configured for this feature and the other one not.
We are using Ethernet over mpls & also TE config is there
Pls suggest possible reason for not showing this
Hi Subhojit,
Do you run LDP over the MPLS TE tunnel? If the targeted LDP is used for EoMPLS, can you please check whether the pseudowire is up?
Sorry for earlier post
we are using this for ldp session protection & found that remite end router LDP session protection config is not present
we will do the config at remote end & let u know
Thanks gor guiding
I found this problem.
I don't know what is the targeted ldp session used for; Eompls, LDP over MPLS TE,  LDP session protection. I saw on
GSR-12000 with configure:
mpls ldp
router-id 10.126.0.30
nsr
graceful-restart
neighbor 10.5.140.3 targeted
log
  neighbor
interface TenGigE0/2/0/0
interface TenGigE0/3/0/0
interface TenGigE0/4/0/0
cdp
mtu 9014
ipv4 address 10.127.0.209 255.255.255.252
load-interval 30
dampening
10.5.140.3 connected with te0/2/0/0 is 7609-S with configure:
interface TenGigabitEthernet4/2
mtu 9000
ip address 10.127.0.210 255.255.255.252
ip router isis
ip pim sparse-mode
load-interval 30
mls qos trust dscp
mpls traffic-eng tunnels
mpls ip
rmon collection history 6 owner campusmanager buckets 10 interval 300
clns mtu 1497
isis circuit-type level-2-only
isis network point-to-point
isis metric 100 level-2
ip rsvp bandwidth 10000000 10000000
end
How should I do
