OSPF flapping issue with Cisco 4500 Switches
vinayak2010
Hi All,
We are having Cisco 4500 switch running on (cat4500e-UNIVERSALK9-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3) with ROM: 15.0(1r)SG7.
Recently we  were having issue with WAN links flap (OSPF neighbor) , The WAN links connected on Gig ports & found nothing wrong on those ports or nothing at WAN provider end.
After reloading switch all come back to normal. but again after a week same issue reoccurred.
is there any Bug causing this weird behavior ?
Nagendra Kumar Nainar
Are you seeing WAN link flap (and so OSPF flap) or just OSPF flap while WAN link stays up?.
Hi Kumar,
WAN link flaps are there. The switch interface where WAN links connected goes up/down repetitively.
Look  at the TSHOOT section in this doc for OSPF , debug ip ospf monitor may help you pinpoint the issue
https://www.cisco.com/networkers/nw00/pres/2206_7-5.pdf
