ospf for multi exit points
sudhakar.aleti
Community Member
Hi Gurus,
Need a suggestion as we have two campus where i have to configure OSPF between the core switches and i have two exist points from these two campus, any link goes down the connectivity has no loss need to take care
R1 and R2 are in a single campus
R3 and R4 are in a single campus
R1 has a default Route towards R5
R4 has a default Route towards R6
Need to configure OSPF between these devices
Please suggest
Sudhakar
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Not quite sure what you're looking to resolve.  Is there a reason why you cannot run OSPF between all the connected routers?
Is the issue, the two off-site exits use defaults?  If so, have your exit edge routers originate OSPF defaults.
Hi Joseph,
Sorry i was not clear, but my requiremnet is
we have two campus in one locations, and each campus has connected with branch office via NLD links and from both the campus we have internet exit points for broswing and i need to configure ospf between these two campus and make 2 default routes at internet exit points.
and orginate the default routes into the ospf for branch office to reach capmus 1 and campus 2 for general browsing (internet).
At the same time i am looking for failover of exit points.
Please let me know if still i am not clear.
Sudhakar
Hello Sudhakar,
having two exit points to the Internet the best choice is to use O E1 routes that take in account both external seed metric and internal metric to reach the ASBR (the router that injects the default route in OSPF in your case).
you can use use
route-map DEFAULT permit 10
set metric-type 1
set metric 50
on devices with static default routes to exit points:
router ospf 10
default-information originate route-map DEFAULT
Hope to help
Giuseppe
