OSPF getting hung in rib
darkleyabove
What is happening is that I have a ppp interface using IPCP that when it fails the OSPF routes learned over that circuit do not clear from the RIB. If I do a show ip ospf neighbors I get 0 entries but the routes are hung until I clear the process.I tried changing times to no avail. Has anyoen ever run into similar? Is there any information I can post which will help in determining the issue? Thanks in advance...
daniel.dib
Level 7
Level 7
Is it possible that the Do Not Age (DNA) bit is set on them? What does the database look like. Can you post output from some LSAs.
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
I would think that the output of show ip ospf might also be helpful in figuring out this issue.
Rick
Rick
Also could you share the IOS and model of the device. Had faced a simliar issue of stale routes injected in BGP,May be a bug.
Sathvik K V
