OSPF:How many ABR's in one area
peter_jevos
Hi , I'd like to ask you how many ABR's are recommended in one area.
I have about 4 ABR's , and everyone is connected into one or more C network, for example:
10.1.1.0
10.1.2.0
10.1.3.0 ....
Should I summarize the routes on every router with 10.1.0.0/16 ?
thank you
pet
5 Replies 5
Sesorov Sergey
It depend off design strategy, size of area, caliber of the routers.
You can summarize on every router
Can i see more of data  (topology, model of routers)
Sergey
thanks for an aswer.
i have 3 routers 1841, and one 1721
one routers has 4 subnets: 10.1.1.0,10.1.2.0,10.1.3.0,10.1.4.0
another routers  have one or two subnets ,in the style of: 10.1.10.0,10.1.11.0 , and so on
All subnets have the same area
All routers have also few tunnels uinto area 0 ( HeadQuater )
Routers are located in the different locations of the couontry, connected with gre ipsec tunnels
All are the ABR's
The questoin is if i should set the summarizing on all of them to 10.1.0.0/16 ?
thanks
All are the ABR's
thanks
Peter
If the routers are in different locations and they all connect back to area 0 then you can't summarise to 10.1.0.0/16 on all the routers because then you will have multiple routes to the 10.1.0.0/16 network with no way of knowing which one is the right one for a particular 10.1.x.0 subnet.  So you will have to advertise the individual subnets or possible summarise but not to 10.1.0.0/16 ie. you will have to be much more specific in how you summarise each sites 10.1.x.0 subnets.
Edit - can you clarify. The routers are all in the same area and they are in different parts of the country. Are they interconnected with each other or only connected via GRE tunnels to area 0 ?
Jon
Than you for your aswer
it makes sense, i will use more specific subnet with the subnet mask
And what about the number of ABR/s per one area ?
Is there any recommendation ?
Another question regarding OSPF.
We have 2 routers as ABR's per area that are connected to the one subnet (e.g. 10.1.1.0 - area 1)
Those two routers have different  ISP each with the tunnels to the area 0
Subnet 10.1.1.0 has one gateway, on the router R1 with 10.1.1.254
How to affect OSPF processes on both routers, that R1 will forward the packets to R2 if it has better costs to the destination ?
Routers are connected only through ethernet segment in area 1.
Because from the OSPF rules, if packet comes to the R1, it sends the packet out of the area1 to the area0, even the R2 has the better cost
One possibility is to create virtual link, another one is to create the tunnel between R! and R2 through area0
Do you know about the others ?
thanks
Dear Jon
thank you for your answer.
Yes , the routers arein the same area with gre tunnels to the headquater ( data center )  in area 0,
there're interconnected also through gre tunels in the their area ( with better cost )
And that's the problem with summarization.
cause as i told you before, one of them keeps 4 C subnets, another ones per C subnets and so on
therefore i cannot summarize on B subnet, e.g. 10.1.0.0/16
