OSPF in NBMA network
feroz syed
Level 3
Level 3
I am running ospf in hub and spoke scenario all frame maps are active and can ping each other, now problem is can’t see any ospf neighbor relations with other routers all three routers are in same subnet and in same area and also checked the hello and dead timer are equal.
2 Accepted Solutions
Hi Feroz,
I hope you are missing neighbor command  on R1.
router ospf 1
neighbor 172.12.123.2
neighbor 172.12.123.3
Hope that helps
Najaf
Please rate when applicable or helpful !!!
Hi Feroz,
you have different options in NBMA. However, if the network type is non-broadcast, it's mandatory to use neighbor statements as the communication is unicast. The use of priority 0 is to prevent that spokes will not participate in the DR/BDR election process.
Other option is to use point-to-multipoint network ospf network type. Here, you do not need to change priority because there is no DR/BDR and also you do not need neighbor statements. However, you need to add the broadcast keyword in the frame map statements between the Hub and Spokes as the communication is multicast - 224.0.0.5.
Hope this helps,
Jose.
12 Replies 12
Akash Agrawal
Hi Feroz,
You need to ensure that router is sending hellos or not, If it is sending hello other device is accepting it or not.
"show ip ospf interface " can tell you if you are sending hello out of this interface or not.
for NBMA network , you need to define neighbor with command "neighbor under ospf process
Router1# show ip ospf interface ethernet 0
Ethernet0 is up, line protocol is up
  Internet Address 10.10.10.1/24, Area 0
  Process ID 1, Router ID 192.168.45.1, Network Type BROADCAST, Cost: 10
  Transmit Delay is 1 sec, State BDR, Priority 1
  Designated Router (ID) 172.16.10.1, Interface address 10.10.10.2
  Backup Designated router (ID) 192.168.45.1, Interface address 10.10.10.1
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    Hello due in 00:00:06                           <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  Index 1/1, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 2, maximum is 2
  Last flood scan time is 0 msec, maximum is 4 msec
  Neighbor Count is 1, Adjacent neighbor count is 1
    Adjacent with neighbor 172.16.10.1  (Designated Router)
  Suppress hello for 0 neighbor(s)
CCO link to configure OSPF over NBMA networks.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009470d.shtml
R1#sh ip ospf int
Loopback1 is up, line protocol is up
  Internet Address 192.168.100.1/24, Area 0
  Process ID 1, Router ID 192.168.100.1, Network Type LOOPBACK, Cost: 1
  Loopback interface is treated as a stub Host
Serial1/0 is up, line protocol is up
  Internet Address 172.12.123.1/24, Area 10
  Process ID 1, Router ID 192.168.100.1, Network Type NON_BROADCAST, Cost: 64
  Transmit Delay is 1 sec, State DR, Priority 1
  Designated Router (ID) 192.168.100.1, Interface address 172.12.123.1
  No backup designated router on this network
  Timer intervals configured, Hello 30, Dead 120, Wait 120, Retransmit 5
    oob-resync timeout 120
    Hello due in 00:00:19
  Supports Link-local Signaling (LLS)
  Cisco NSF helper support enabled
  IETF NSF helper support enabled
  Index 1/2, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 0, maximum is 0
  Last flood scan time is 0 msec, maximum is 0 msec
  Neighbor Count is 0, Adjacent neighbor count is 0
R2#sh ip ospf int
  Internet Address 192.168.100.2/24, Area 0
  Process ID 1, Router ID 192.168.100.2, Network Type LOOPBACK, Cost: 1
Serial1/2 is up, line protocol is up
  Internet Address 172.12.123.2/24, Area 10
  Process ID 1, Router ID 192.168.100.2, Network Type NON_BROADCAST, Cost: 64
  Designated Router (ID) 192.168.100.2, Interface address 172.12.123.2
    Hello due in 00:00:17
  Next 0x0(0)/0x0(0)
R3#sh ip ospf int
  Internet Address 192.168.100.3/24, Area 0
  Process ID 1, Router ID 192.168.100.3, Network Type LOOPBACK, Cost: 1
Serial1/3 is up, line protocol is up
  Internet Address 172.12.123.3/24, Area 10
  Process ID 1, Router ID 192.168.100.3, Network Type NON_BROADCAST, Cost: 64
  Designated Router (ID) 192.168.100.3, Interface address 172.12.123.3
    Hello due in 00:00:00
  Next 0x0(0)/0x0(0)
R1#sh ip ospf int
  Next 0x0(0)/0x0(0)
R2#sh ip ospf int
  Next 0x0(0)/0x0(0)
R3#sh ip ospf int
  Next 0x0(0)/0x0(0)
Hi Feroz,
Please share OSPF configuration for all 3 routers. You can also run "debug ip ospf adj" to collect more logs.
Akash
If layer 2 it's fine as you said and you have configured the neighbor statements as Akash said, then configure priority 255 in the Hub - R1, priority 0 in the spokes, then clear ip ospf process and it should work.
Best Regards,
Jose.
R3#debug ip ospf adj
OSPF adjacency events debugging is on
R3#cle
R3#clear ip os
R3#clear ip ospf pr
R3#clear ip ospf process
Reset ALL OSPF processes? [no]: y
R3#
*Jun  5 11:54:23.415: OSPF: Interface Loopback1 going Down
*Jun  5 11:54:23.415: OSPF: 192.168.100.3 address 192.168.100.3 on Loopback1 is dead, state DOWN
*Jun  5 11:54:23.455: OSPF: Interface Serial1/3 going Down
*Jun  5 11:54:23.455: OSPF: 192.168.100.3 address 172.12.123.3 on Serial1/3 is dead, state DOWN
*Jun  5 11:54:23.455: OSPF: Neighbor change Event on interface Serial1/3
*Jun  5 11:54:23.459: OSPF: DR/BDR election on Serial1/3
*Jun  5 11:54:23.459: OSPF: Elect BDR 0.0.0.0
*Jun  5 11:54:23.459: OSPF: Elect DR 0.0.0.0
*Jun  5 11:54:23.459:        DR: none    BDR: none
R3#
*Jun  5 11:54:23.463: OSPF: Flush network LSA immediately
*Jun  5 11:54:23.463: OSPF: Remember old DR 192.168.100.3 (id)
*Jun  5 11:54:23.547: OSPF: Interface Loopback1 going Up
*Jun  5 11:54:23.547: OSPF: Interface Serial1/3 going Up
*Jun  5 11:54:23.915: OSPF: Build router LSA for area 0, router ID 192.168.100.3, seq 0x80000001, process 1
*Jun  5 11:54:23.963: OSPF: We are not DR to build Net Lsa for interface Serial1/3
*Jun  5 11:54:23.963: OSPF: Build router LSA for area 10, router ID 192.168.100.3, seq 0x80000001, process 1R3#debug ip ospf adj
R3#cle
R3#clear ip os
R3#clear ip ospf pr
R3#
R3#
Post your configs and make sure you configured the  static neighbours on the hub   and the OSPF priority to zero on the spokes interfaces.
Alain
It would be helpful if you explain me why we need to change priority on spoke routers.
interface Loopback1
ip address 192.168.100.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 172.12.123.1 255.255.255.0
encapsulation frame-relay IETF
serial restart-delay 0
frame-relay map ip 172.12.123.3 103
frame-relay map ip 172.12.123.2 102
no frame-relay inverse-arp
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 172.12.123.0 0.0.0.255 area 10
network 192.168.100.0 0.0.0.255 area 0
interface Loopback1
ip address 192.168.100.2 255.255.255.0
no ip address
shutdown
duplex half
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
ip address 172.12.123.2 255.255.255.0
frame-relay map ip 172.12.123.3 201
frame-relay map ip 172.12.123.1 201
interface Serial1/3
no ip address
shutdown
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/1
no ip address
shutdown
duplex auto
speed auto
router ospf 1
interface Loopback1
ip address 192.168.100.3 255.255.255.0
no ip address
shutdown
duplex half
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
ip address 172.12.123.3 255.255.255.0
frame-relay map ip 172.12.123.2 301
frame-relay map ip 172.12.123.1 301
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 1
interface Loopback1
no ip address
shutdown
duplex half
interface Serial1/0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
Router 2
interface Loopback1
no ip address
shutdown
duplex half
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
interface Serial1/3
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 1
Router 3
interface Loopback1
no ip address
shutdown
duplex half
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 1
Hi Feroz,
router ospf 1
Hope that helps
Najaf
As the network type is non-broadcast, a DR is needed for the database synchronization. The spokes must synchronize their databases with the Hub, which must be the DR. The spokes do not have direct communication between them, so they could not sync their databases.
I would hardcode the router-id as well and configure the neighbor statements as they are missing in the config.
Hope this helps,
Jose.
HI Feroz,
From your debug output it looks like your loopback interface is going down (very strange:-). Router would be using the loopback address as the router id for the OSPF process.
If you have necessary configuration as adviced in previous post by other experts and if you ensure your interface remains up up i think that should fix the issue.
Hope that helps
Najaf
feroz syed
Level 3
Level 3
So when OSPF running in nbma network it's mandatory to execute "neighbour cmd " and making priority 0 on spoke routers .
Hi Feroz,
Hope this helps,
Jose.
