OSPF inter-area networks not learned
I am having problem in ospf. In topology i was trying to connect non-backbone areas for that i created virtual link from 3.3.3.1 to 6.6.6.1 but problem remain same as i am getting routes on all routers except one that is 7.7.7.1 who's having routes of area 0 but not area 50. So please help me to resolve this
10 Replies 10
hard to say without seeing the configs, can you post them ?
What is the output of:
show ip ospf virtual-links
Router 7 (7.7.7.1)
The routing table:
R7#show ip route
Gateway of last resort is not set
6.0.0.0/32 is subnetted, 1 subnets
O 6.6.6.1/32 [110/65] via 40.0.0.1, 00:00:19, Serial0/3/0
7.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 7.7.7.0/30 is directly connected, Loopback7
L 7.7.7.1/32 is directly connected, Loopback7
40.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 40.0.0.0/30 is directly connected, Serial0/3/0
L 40.0.0.2/32 is directly connected, Serial0/3/0
Router 6 (6.6.6.1)
The routing table:
R6#show ip route
1.0.0.0/32 is subnetted, 1 subnets
O 1.1.1.1/32 [110/130] via 30.0.0.1, 00:08:41, GigabitEthernet0/0
2.0.0.0/32 is subnetted, 1 subnets
O 2.2.2.1/32 [110/66] via 30.0.0.1, 00:08:41, GigabitEthernet0/0
3.0.0.0/32 is subnetted, 1 subnets
O 3.3.3.1/32 [110/2] via 30.0.0.1, 00:08:41, GigabitEthernet0/0
4.0.0.0/32 is subnetted, 1 subnets
O 4.4.4.1/32 [110/2] via 30.0.0.3, 00:09:06, GigabitEthernet0/0
5.0.0.0/32 is subnetted, 1 subnets
O 5.5.5.1/32 [110/2] via 30.0.0.4, 00:09:06, GigabitEthernet0/0
6.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 6.6.6.0/30 is directly connected, Loopback6
L 6.6.6.1/32 is directly connected, Loopback6
7.0.0.0/32 is subnetted, 1 subnets
O 7.7.7.1/32 [110/65] via 40.0.0.2, 00:09:46, Serial0/3/0
10.0.0.0/30 is subnetted, 1 subnets
O 10.0.0.0/30 [110/129] via 30.0.0.1, 00:08:41, GigabitEthernet0/0
20.0.0.0/30 is subnetted, 1 subnets
O 20.0.0.0/30 [110/65] via 30.0.0.1, 00:08:41, GigabitEthernet0/0
30.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 30.0.0.0/29 is directly connected, GigabitEthernet0/0
L 30.0.0.2/32 is directly connected, GigabitEthernet0/0
L 40.0.0.1/32 is directly connected, Serial0/3/0
OSPF Virtual-links :
R6#show ip ospf virtual
Virtual Link OSPF_VL0 to router 3.3.3.1 is up
Run as demand circuit
Transit area 50, via interface GigabitEthernet0/0, Cost of using 1
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
Hello due in 00:00:01
Adjacency State FULL
Index 1/2, retransmission queue length 0, number of retransmission 0
First 0x0(0)/0x0(0) Next 0x0(0)/0x0(0)
Last retransmission scan length is 0, maximum is 0
Last retransmission scan time is 0 msec, maximum is 0 msec
Router 5 (5.5.5.1)
The routing table :
R5(config)#do show ip route
O IA 1.1.1.1/32 [110/130] via 30.0.0.1, 00:11:36, GigabitEthernet0/0
O IA 2.2.2.1/32 [110/66] via 30.0.0.1, 00:11:36, GigabitEthernet0/0
O IA 3.3.3.1/32 [110/2] via 30.0.0.1, 00:11:36, GigabitEthernet0/0
O 4.4.4.1/32 [110/2] via 30.0.0.3, 00:11:36, GigabitEthernet0/0
5.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 5.5.5.0/30 is directly connected, Loopback5
L 5.5.5.1/32 is directly connected, Loopback5
O IA 6.6.6.1/32 [110/2] via 30.0.0.2, 00:11:36, GigabitEthernet0/0
O IA 7.7.7.1/32 [110/66] via 30.0.0.2, 00:11:36, GigabitEthernet0/0
O IA 10.0.0.0/30 [110/129] via 30.0.0.1, 00:11:36, GigabitEthernet0/0
O IA 20.0.0.0/30 [110/65] via 30.0.0.1, 00:11:36, GigabitEthernet0/0
L 30.0.0.4/32 is directly connected, GigabitEthernet0/0
40.0.0.0/30 is subnetted, 1 subnets
O IA 40.0.0.0/30 [110/65] via 30.0.0.2, 00:11:36, GigabitEthernet0/0
Router 7 (7.7.7.1)
The routing table:
R7#show ip route
Router 6 (6.6.6.1)
The routing table:
R6#show ip route
Router 5 (5.5.5.1)
The routing table :
Router 3 (3.3.3.1)
The routing table :
R3(config)#do show ip route
O 1.1.1.1/32 [110/129] via 20.0.0.1, 00:16:03, Serial0/3/0
O 2.2.2.1/32 [110/65] via 20.0.0.1, 00:16:03, Serial0/3/0
3.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 3.3.3.0/30 is directly connected, Loopback3
L 3.3.3.1/32 is directly connected, Loopback3
O 4.4.4.1/32 [110/2] via 30.0.0.3, 00:15:33, GigabitEthernet0/0
O 5.5.5.1/32 [110/2] via 30.0.0.4, 00:15:33, GigabitEthernet0/0
O IA 6.6.6.1/32 [110/2] via 30.0.0.2, 00:14:58, GigabitEthernet0/0
O IA 7.7.7.1/32 [110/66] via 30.0.0.2, 00:14:58, GigabitEthernet0/0
O 10.0.0.0/30 [110/128] via 20.0.0.1, 00:16:03, Serial0/3/0
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 20.0.0.0/30 is directly connected, Serial0/3/0
L 20.0.0.2/32 is directly connected, Serial0/3/0
L 30.0.0.1/32 is directly connected, GigabitEthernet0/0
O IA 40.0.0.0/30 [110/65] via 30.0.0.2, 00:14:58, GigabitEthernet0/0
R3(config)#do show ip ospf virtual-links
Virtual Link OSPF_VL0 to router 6.6.6.1 is up
Hello due in 00:00:06
Hello
Is the transit area area 50?
sh ip ospf virtual-links
sh ip route ospf
Kind Regards
Paul
I've posted the configurations also please check it .
also thank you for the remark
Cristian Matei
   Post the configuration of all routers, and the output of "show ip ospf neighbor", "show ip ospf | i ID" and "show ip route ospf" from all routers.
Cristian Matei.
Okay fine i will post it
    The problem is between R6 and R7. Post the configuration of R6 and R7, and the output of "show ip ospf neighbor", "show ip ospf | i ID", "show ip route ospf", "show ip ospf database 1.1.1.1", "show ip ospf database 5.5.5.1" from R6 and R7.
Cristian Matei.
Router 6
Neighbor:
R6#show ip ospf nei
00:01:20: %OSPF-5-ADJCHG: Process 1, Nbr 3.3.3.1 on OSPF_VL0 from LOADING to FULL, Loading Done
Neighbor ID Pri State Dead Time Address Interface
3.3.3.1 0 FULL/ - 00:00:39 30.0.0.1 OSPF_VL0
3.3.3.1 10 FULL/DR 00:00:39 30.0.0.1 GigabitEthernet0/0
4.4.4.1 1 FULL/DROTHER 00:00:39 30.0.0.3 GigabitEthernet0/0
5.5.5.1 1 FULL/DROTHER 00:00:39 30.0.0.4 GigabitEthernet0/0
7.7.7.1 0 FULL/ - 00:00:39 40.0.0.2 Serial0/3/0
Show ip ospf interface:
R6#show ip ospf interface
GigabitEthernet0/0 is up, line protocol is up
Internet address is 30.0.0.2/29, Area 50
Process ID 1, Router ID 6.6.6.1, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State BDR, Priority 1
Designated Router (ID) 3.3.3.1, Interface address 30.0.0.1
Backup Designated Router (ID) 6.6.6.1, Interface address 30.0.0.2
Hello due in 00:00:05
Index 1/1, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 1, maximum is 1
Last flood scan time is 0 msec, maximum is 0 msec
Neighbor Count is 3, Adjacent neighbor count is 3
Adjacent with neighbor 3.3.3.1 (Designated Router)
Adjacent with neighbor 4.4.4.1
Adjacent with neighbor 5.5.5.1
Suppress hello for 0 neighbor(s)
Loopback6 is up, line protocol is up
Internet address is 6.6.6.1/30, Area 100
Process ID 1, Router ID 6.6.6.1, Network Type LOOPBACK, Cost: 1
Loopback interface is treated as a stub Host
Serial0/3/0 is up, line protocol is up
Internet address is 40.0.0.1/30, Area 100
Process ID 1, Router ID 6.6.6.1, Network Type POINT-TO-POINT, Cost: 64
Transmit Delay is 1 sec, State POINT-TO-POINT, Priority 0
No designated router on this network
No backup designated router on this network
Index 3/3, flood queue length 0
Next 0x0(0)/0x0(0)
Neighbor Count is 1 , Adjacent neighbor count is 1
Adjacent with neighbor 7.7.7.1
OSPF_VL0 is up, line protocol is up
Internet address is 30.0.0.2/29, Area 0
Process ID 1, Router ID 6.6.6.1, Network Type VIRTUAL_LINK, Cost: 1
Configured as demand circuit.
Run as demand circuit.
DoNotAge LSA allowed.
oob-resync timeout 40
Hello due in 00:00:00
Supports Link-local Signaling (LLS)
Index 4/4, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 0
Show ip route ospf:
R6#Show ip route ospf
O 1.1.1.1 [110/130] via 30.0.0.1, 00:05:52, GigabitEthernet0/0
O 2.2.2.1 [110/66] via 30.0.0.1, 00:05:52, GigabitEthernet0/0
O 3.3.3.1 [110/2] via 30.0.0.1, 00:05:52, GigabitEthernet0/0
O 4.4.4.1 [110/2] via 30.0.0.3, 00:06:17, GigabitEthernet0/0
O 5.5.5.1 [110/2] via 30.0.0.4, 00:06:17, GigabitEthernet0/0
O 7.7.7.1 [110/65] via 40.0.0.2, 00:07:07, Serial0/3/0
O 10.0.0.0 [110/129] via 30.0.0.1, 00:05:52, GigabitEthernet0/0
O 20.0.0.0 [110/65] via 30.0.0.1, 00:05:52, GigabitEthernet0/0
Show ip ospf database :
R6#Show ip ospf database
OSPF Router with ID (6.6.6.1) (Process ID 1)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
6.6.6.1 6.6.6.1 617 0x80000002 0x004bb5 1
2.2.2.1 2.2.2.1 672 0x80000006 0x00d7dd 5
1.1.1.1 1.1.1.1 672 0x80000003 0x00ff8e 3
3.3.3.1 3.3.3.1 632 0x80000005 0x00130d 4
Summary Net Link States (Area 0)
6.6.6.1 6.6.6.1 662 0x80000002 0x00181f
40.0.0.0 6.6.6.1 662 0x80000003 0x00558f
7.7.7.1 6.6.6.1 662 0x80000004 0x00727f
30.0.0.0 6.6.6.1 617 0x80000005 0x0043ec
4.4.4.1 6.6.6.1 617 0x80000006 0x0062d5
5.5.5.1 6.6.6.1 617 0x80000007 0x003cf7
30.0.0.0 3.3.3.1 672 0x80000001 0x0093a9
4.4.4.1 3.3.3.1 632 0x80000002 0x00b292
5.5.5.1 3.3.3.1 632 0x80000003 0x008cb4
Router Link States (Area 50)
4.4.4.1 4.4.4.1 642 0x80000003 0x0028b2 2
5.5.5.1 5.5.5.1 642 0x80000004 0x001cb3 2
3.3.3.1 3.3.3.1 632 0x80000005 0x0059a4 1
6.6.6.1 6.6.6.1 617 0x80000005 0x00b139 1
Net Link States (Area 50)
30.0.0.1 3.3.3.1 637 0x80000003 0x008938
Summary Net Link States (Area 50)
6.6.6.1 6.6.6.1 662 0x80000001 0x001a1e
40.0.0.0 6.6.6.1 662 0x80000002 0x00578e
7.7.7.1 6.6.6.1 662 0x80000003 0x00747e
3.3.3.1 3.3.3.1 672 0x80000001 0x00ce7b
20.0.0.0 3.3.3.1 672 0x80000002 0x00a45e
2.2.2.1 3.3.3.1 662 0x80000003 0x007199
10.0.0.0 3.3.3.1 662 0x80000004 0x00a525
1.1.1.1 3.3.3.1 662 0x80000005 0x0014b7
3.3.3.1 6.6.6.1 587 0x80000009 0x0080b7
20.0.0.0 6.6.6.1 587 0x8000000a 0x00569a
2.2.2.1 6.6.6.1 587 0x8000000b 0x0023d5
10.0.0.0 6.6.6.1 587 0x8000000c 0x005761
1.1.1.1 6.6.6.1 587 0x8000000d 0x00c5f3
Router Link States (Area 100)
6.6.6.1 6.6.6.1 672 0x80000003 0x00d53f 3
7.7.7.1 7.7.7.1 672 0x80000003 0x008c82 3
Summary Net Link States (Area 100)
3.3.3.1 6.6.6.1 597 0x80000001 0x0090af
20.0.0.0 6.6.6.1 597 0x80000002 0x006791
2.2.2.1 6.6.6.1 597 0x80000003 0x0033cd
10.0.0.0 6.6.6.1 597 0x80000004 0x006759
1.1.1.1 6.6.6.1 597 0x80000005 0x00d5eb
Router 7
Neighbor:
R7#show ip ospf neig
6.6.6.1 0 FULL/ - 00:00:39 40.0.0.1 Serial0/3/0
R7#show ip ospf interface
Loopback7 is up, line protocol is up
Internet address is 7.7.7.1/30, Area 100
Process ID 2, Router ID 7.7.7.1, Network Type LOOPBACK, Cost: 1
Internet address is 40.0.0.2/30, Area 100
Process ID 2, Router ID 7.7.7.1, Network Type POINT-TO-POINT, Cost: 64
Index 2/2, flood queue length 0
Next 0x0(0)/0x0(0)
Adjacent with neighbor 6.6.6.1
Show ip route ospf:
R7#Show ip route ospf
O IA 1.1.1.1 [110/194] via 40.0.0.1, 00:15:16, Serial0/3/0
O IA 2.2.2.1 [110/130] via 40.0.0.1, 00:15:16, Serial0/3/0
O IA 3.3.3.1 [110/66] via 40.0.0.1, 00:15:16, Serial0/3/0
O 6.6.6.1 [110/65] via 40.0.0.1, 00:16:31, Serial0/3/0
O IA 10.0.0.0 [110/193] via 40.0.0.1, 00:15:16, Serial0/3/0
O IA 20.0.0.0 [110/129] via 40.0.0.1, 00:15:16, Serial0/3/0
R7#Show ip ospf database
OSPF Router with ID (7.7.7.1) (Process ID 2)
7.7.7.1 7.7.7.1 1046 0x80000003 0x008c82 3
6.6.6.1 6.6.6.1 1046 0x80000003 0x00d53f 3
3.3.3.1 6.6.6.1 971 0x80000001 0x0090af
20.0.0.0 6.6.6.1 971 0x80000002 0x006791
2.2.2.1 6.6.6.1 971 0x80000003 0x0033cd
10.0.0.0 6.6.6.1 971 0x80000004 0x006759
1.1.1.1 6.6.6.1 971 0x80000005 0x00d5eb
   Per your output, i see the route there now:
Cristian Matei.
