nat failing iosv - no output from sh ip nat translations
OscarChacon
My configuration seems to be ok, but NAT is failing from 10.10.1.1/24 network.
Here is my NAT config
ip access-list 10 permit 10.0.0.0 0.0.255.255
interface e1/0
ip address 172.16.1.2 255.255.255.0
ip nat outside
interface e1/1
ip nat inside
int loopback 25
ip address 172.16.16.16 255.255.255.0
ip nat inside source list 10 interface Loopback25 overload
I'm running a test ping but not getting anything on the 'show ip nat translations'
alan_schneider
your problem is the wildcard mask on the access-list. You should change it to 0.255.255.255 if you want to match 10.10.1.1/24 network.
ip access-list 10 permit 10.0.0.0 0.0.255.255 <- this only matches 10.0.x.x it won't match 10.10.1.X
5 Replies 5
alan_schneider
Thanks. I don't know how I missed that.
on a side note:
--> your problem is the wildcard mask on the access-list. You should change it to 0.255.255.255 if you want to match 10.10.1.1/24 network.
Shouldn't the wildcard mask be 0.0.0.255 then ? 0.255.255.255 would only match 10.0.0.0.
Either way, the access list should be:
ip access-list 10 permit 10.0.0.0 0.0.0.255
His ip was 10.10.1.1/24.
0.255.255.255 would match the entire 10.0.0.0/8 <-10.10.x.x matched
0.0.0.255 would only match 10.0.0.0/24 <- 10.10.x.x not matched
you are right. I guess what I wanted to point out is that the match should be as close as possible.
10.10.1.1/24
should translate to:
ip access-list 10 permit 10.10.1.0 0.0.0.255
Yours (10.0.0.0 0.255.255.255) would match as well, but it includes the entire class A network.
