OSPF - interconnecting another domain
tjskier69
Hi folks again,
I have another question, which is how you interconnect 2 or more OSPF domains or AS's together so that each AS would see the other routes as external. Would BGP be really necessary? Also assume that a private connection between them does is a possibility.
Any ideas.
pkhatri
Level 11
Level 11
All routes injected into one OSPF domain from another appear as external - you don't have a choice in the matter.
BGP is not necessary. In the context of Cisco IOS, you could run 2 separate OSPF processes and redistribute between them.
Hope that helps - pls rate the post if it does.
Paresh
arvindchari
Level 3
Level 3
In addition to Paresh's post, Id like to add that you can match only selected types of LSA's to be redistrubuted. Ive found this invaluable in a couple of instances.
Here's a sample configuration:
Router1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router1(config)#router eigrp 11
Router1(config-router)#redistribute ospf 55 match external type 1
Router1(config-router)#end
Router1#
Please rate posts that help
Arvind
balajitvk
Level 4
Level 4
Hi skier,
You can very well interconnect two different ospf domains with the redistribution of routes among them.
Here is the site to provide some configuration examples,
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080531fd2.shtml#singlered
Rgs,
