OSPF Issue
Michele Toblini
We got one couple 4500x in vss with this release IOS XE Release 3.4.6SG and one couple of 6800 also in vss. We configured a span with source the port-channel that connects the switches going to a security appliance.
The ospf neighbor went down and it came up as soon as we shutted down the port of the appliance.
I searched for a known bug but i couldn't find anything.
Thoughts?
Michele
Jaderson Pessoa
@Michele Toblini  hello,
Is there any vlan associate on this port-channel?  If yes, this vlan is created just for span?
Only traffic that enters or leaves source ports or traffic that enters or leaves source VLANs can be monitored by using SPAN; traffic routed to a source VLAN cannot be monitored. For example, if incoming traffic is being monitored, traffic that gets routed from another VLAN to the source VLAN cannot be monitored; however, traffic that is received on the source VLAN and routed to another VLAN can be monitored.
Jaderson Pessoa
*** Rate All Helpful Responses ***
yeah all vlans are point to points on which ospf forms neighborship for different vrfs
Could you share current configuration of this port-channel and current configuration of ospf?
Jaderson Pessoa
I found the bug related to 4500-x, https://quickview.cloudapps.cisco.com/quickview/bug/CSCup89543
Problem solved :) Thanks for your help.
