OSPF load balancing on multi link NSSA
saeedkhalid
Dear fellas I need some help on this pls
I have a CE connected to my PE via two leased lines of equal BW and costs for load balancing and sharing. OSPF is running b/w the two in area 2020 such that the two Leased lines are treated as seperate paths and neighbourship establishes on both against the ruter ID which is the Lo0 int.
The issue is that if I configure the network b/w the PE and CE as NSSA then ospf only shows one path to routes learned from each other.
If nssa command is removed then both paths are seen for the routes and traffic is load balanced.
I apologise for my ill-letracy.
Kashif
Hello Saeed,
when you set area type to NSSA the following happens:
node CE becomes an NSSA ASBR and generates LSA type 7 that are confined to the NSSA area ( area scope)
node PE becomes an NSSA ABR that performs LSA translation from type 7 to type 5 according to the rules described in OSPF NSSA RFC
http://www.faqs.org/rfcs/rfc3101.html
section 3
if you remove the NSSA option area 2020 becomes a standard area, CE node a standard ASBR that generates LSA type 5 diretly, PE node becomes a standard ABR and the type 5 LSA is flooded unchanged in the OSPF domain
In adddition to this using 0.0.0.0 wildcard has specific effects on the forwarding address field
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009405a.shtml#topic1
you can try the following:
use network command + passive interface instead of redistribute connected
OR
change wildcard mask to 0.0.0.3 aligned to subnet mask in network commands describing p2p links CE-PE
Hope to help
Giuseppe
boss.silva
Can you please post a sanitized running-configuration of your CE and PE routers?
Bruno Silva.
Dear here is the config:
CE
interface FastEthernet0/1/0
description ***       ***
ip address x.x.x.2 255.255.255.252
load-interval 30
interface FastEthernet0/1/1
description ***      ***
ip address x.x.x.6 255.255.255.252
load-interval 30
router ospf 2020
router-id x.x.x.105
log-adjacency-changes
redistribute connected metric 100 metric-type 1 subnets tag 2020
area 2020 nssa
network x.x.x.2 0.0.0.0 area 2020
network x.x.x.6 0.0.0.0 area 2020
ip classless
PE
interface GigabitEthernet1/0/1
no switchport
ip address x.x.x.1 255.255.255.252
interface GigabitEthernet1/0/2
no switchport
ip address x.x.x.5 255.255.255.252
router ospf 35457
router-id x.x.x.115
log-adjacency-changes detail
auto-cost reference-bandwidth 1000
area 0 authentication message-digest
redistribute connected metric 100 metric-type 1 subnets tag 222
area 2020 nssa default-information-originate
  network x.x.x.1 0.0.0.0 area 2020
network x.x.x.5 0.0.0.0 area 2020
Hello Saeed,
section 3
OR
Hope to help
Giuseppe
Dear Gluseppe
THNX a lot for your help its now working with the network commands
The issue is that it treats the network as LSA7 when useing the redistribute command as its importing from connected or static.
The links you refered are excelent.
