PFR Based Load Balancing
Dipesh Patel
Level 2
Level 2
Dear experts,
Can you suggest how pfr will be configured for the load balancing?
I have some queries regarding the same:
  • I have two MPLS links from two different SP. Both terminated on independent CE routers. Can We configure one CE router as BR and MC?
  • If I configure pfr for loadbalacning it may have chance of assymetroc routing. Will it be affect GETVPN?
  • Please suggest the iOS which will spport GETVPN and PFR as we are on the verge of implementing GETVPN and pfr.
  • Is there any specificimpact on resource utilization after impmentation of pfr?
I am attaching here the topology for your refference. Kindly suggest the design and configuration, which router I should configure as a BR and which one as a MC?
Marwan ALshawi
answers to you questions as bellow
- yes you can have both BR and MC on the same router
- PfR is routing feature while GETVPN is security feature if you have licensing for routing and security then you can have bot on the same router
- i suggest you to do a prove of concept for this PfR as i think it depends on the policies you have in the PfR, how much your routing flap, link utilization ..etc
- if you have assymetric routing i think it could effect the vpn interms of encrypt and decrypte the traffic
if helpful rate
