OSPF load balancing
v.nastase
Level 2
Level 2
Does anybody know how to deploy load balancing in OSPF area 0 ?
Any suggestion for documentation would be apreciated.
Thanks in advance for your help
Aaron Harrison
OSPF only does equal-cost load balancing, so you must have two routes with equal costs to the destination.
Also this command must be set to more than one:
maximum-paths
under router ospf configuration.
I think you also need ip cef enabled.
See this link for more info:
http://www.cisco.com/warp/public/105/loadbal_cef.html#beforecef
Aaron
Hope this helps - don't forget to rate posts 🙂
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
maximum-paths
Aaron
I have 2 clarifications to this post.
The post says that maximum paths must be set to more than one which implies that you need to do something in your config. Maximum paths has a default value of 4. So while you can specify a value for maximum-paths it is not required to configure this parameter to load share.
The post also thinks that you need ip cef enabled. While enabling ip cef is generally a good thing and on general principles I would think that you should enable ip cef, it is not required to do load sharing.
So the first line of the post is really the answer: OSPF does equal cost load balancing and if you have two routes with equal cost to the destination then OSPF will load share.
Rick
Rick
Could I add just one bit of extra information to what Rick says, and mention something that might trip you up if you are not aware of it.
If you are running CEF, then the load-sharing by default is per-flow (so called "per-destination", but actually per flow). That is, all packets for a particular pair of IP addresses will take the same path, so their order of arrival is guaranteed. If you are process-switching, then the load sharing is per-packet - that is, packets from a single session can take different paths, so they could arrive out of order, which could upset some applications.
You can configure CEF to do per-packet, but it is not usually advisable.
And I cannot remember off the top of my head how fast-cache switching behaves, but I think it is also per-destination - so there is not any danger of packets arriving out of order.
Kevin Dorrell
Luxembourg
