Ospf logs and snmp Server.
ronakmaniar
I have 3750E with c3750e-universalk9-mz.122-50.SE3 IOS. I have two redundant Links to different ISPs with equal Cost. G0/1 and G0/2, both are advertised in ospf within same area with equal cost. I have snmp enable traps and my snmp is connected in a remote location via these ospf links.
Normally snmp-serve receives these traps via G0/2 link and when G0/2 link fails the snmp-server will receive these traps via g0/1. But in this case snmp-server does not receive the Adj-changes logs OR G0/2 down logs. Logs are generated on local Switch but they are not seen on SNMP-SERVER, so in this case Person Monitoring the snmp-server cannot identify that the link g0/2 is now down or ospf nei is down via g0/2.
help me to resolve this issue.
interface Loopback10
ip address 4.4.4.4 255.255.255.255
interface GigabitEthernet0/1
description =================) normal Snmp tarps are sent from this link after Ge 0/2 goes down = Secondary
no switchport
ip address 10.10.10.1 255.255.255.248
ip ospf network point-to-point
ip ospf cost 10
interface GigabitEthernet0/2
description =================) normal Snmp tarps are sent from this link = primary.
no switchport
ip address 20.20.20.3 255.255.255.248
ip ospf cost 10
router ospf 3
router-id 4.4.4.4
log-adjacency-changes
network 4.4.4.4 0.0.0.0 area 0
network 10.10.10.3 0.0.0.7 area 0
network 20.20.20.3 0.0.0.7 area 0
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
Above config is already deployed on the switch.
Can Anyone help me here.
I have a similar problem with OSPF logs generated on ISR4321 and ISR4221. The logs on the logging monitor, but they do not appear on the syslog server. All other messages do come through. Did you resolve this issue?
