Cisco 4300 ISR IOS upgrade issues
Starfish
I have a cisco 4331 router where I need to upgrade OS to higher version. Current version:
#sh version
Cisco IOS XE Software, Version 16.06.02
I have OS for version16.6.3 in the bootflash and have changed the boot marker but when I reload the router, it will still stick to version 16.06.02
As below, this is where the marker is pointing to the current image but after reload the version remains 16.06.02, please help!!
boot-start-marker
boot system flash bootflash:
boot system flash bootflash:isr4300-universalk9.16.06.03.SPA.bin
boot-end-marker
diagnostic bootup level minimal
path bootflash:cfg
Thanks in advance
I would try this :
(Config)# no boot system flash bootflash:
And just leave the:
Save and reload, I had a similar issue. If that doesn't work, like Leo mentioned , we will need to see the entire boot up process
6 Replies 6
Hulk8647
can you type these in and show results?
#show bootvar
#show version
#show runn  | i boot
R1#sh bootvar
BOOT variable = bootflash:,1;bootflash:isr4300-universalk9.16.06.03.SPA.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
R1#sh ver
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 01-Nov-17 07:09 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2017 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
R1 uptime is 2 hours, 0 minutes
Uptime for this control processor is 2 hours, 3 minutes
System returned to ROM by Reload Command at 14:53:23 edt Wed Mar 28 2018
System restarted at 14:59:43 edt Wed Mar 28 2018
System image file is "bootflash:isr4300-universalk9.16.06.02.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 Permanent appxk9
uck9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 None ipbasek9
cisco ISR4331/K9 (1RU) processor with 7940760K/6147K bytes of memory.
Processor board ID FLM2126W0UA
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
14659583K bytes of flash memory at bootflash:.
20971520K bytes of SATA hard disk at harddisk:.
0K bytes of WebUI ODM Files at webui:.
R1# sh run | i boo
R1# sh run | i boot
boot-start-marker
boot-end-marker
path bootflash:cfg
access-list 101 permit udp any any eq bootpc
I would try this :
And just leave the:
Leo Laohoo
Connect a console cable to the router and reboot. Post the entire boot-up process.
Hi Starfish,
Did you solve this issue?
i have similliar issue with my ISR 4331.
Ovindo
Can you please create a new thread?
