Routing between VRF on Cisco 881
Webwalker
on top of our DMVPN config we have created an additional VRF on a Cisco 881 [15.4(3)M8] which is a second internet connection meant for voice services. Between the LAN VRF and the new additional voice VRF we`ve created a direct physical connection (ethernet cable) to route some IPs from existing VRF to voice VRF.
Problem we are having is that we cannot even ping the IPs of the VLAN interfaces.
interface FastEthernet0
 description Transfer VRF -> connected with cable to FA2
 switchport access vlan 300
 no ip address
 duplex full
 speed 100
interface FastEthernet1
 description LAN
 switchport access vlan 101
 no ip address
 duplex full
 speed 100
interface FastEthernet2
 description Transfer VRF -> connected with cable to FA0
 switchport access vlan 302
 no ip address
 duplex full
 speed 100
interface FastEthernet3
 description LAN
 switchport access vlan 303
 no ip address
 duplex full
 speed 100
interface FastEthernet4
 description ISP
 mtu 1492
 ip vrf forwarding internet
 ip address dhcp
 ip access-group 100 in
 duplex auto
 speed auto
interface Vlan101
 description LAN
 ip vrf forwarding BBNIG
 ip address 10.230.1.1 255.255.255.0
 ip virtual-reassembly in
interface Vlan300
 ip address 10.127.251.33 255.255.255.248
interface Vlan302
 ip vrf forwarding SIP
 ip address 10.127.251.34 255.255.255.248
interface Vlan303
 description internet for voice
 ip address 192.168.8.254 255.255.255.0
ip route vrf SIP 0.0.0.0 0.0.0.0 192.168.8.1
ip route vrf SIP 10.0.0.0 255.0.0.0 10.127.251.33
ip route vrf BBNIG <SIP GTW> 255.255.255.255 10.127.251.34
Any idea why we cannot even ping the 10.127.251.33 / 10.127.251.34 from the opposite VRF even if directly connected?
sh ip route vrf SIP
Gateway of last resort is 192.168.8.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.8.1
      10.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
S        10.0.0.0/8 [1/0] via 10.127.251.33
C        10.127.251.32/29 is directly connected, Vlan302
L        10.127.251.34/32 is directly connected, Vlan302
      192.168.8.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.8.0/24 is directly connected, Vlan303
L        192.168.8.254/32 is directly connected, Vlan303
Webwalker
12 Replies 12
omz
Fa0 connected to Fa2 on the same router like a physical loopback? Is it supposed to work? I am very interested to know.
Why use VRFs if routing between them is required?
a.alekseev
Level 7
Level 7
You must create two static arp to make  this working...
How exactly should these ARP entires be configured?
Edited:
Hello
Vrf enables you to segregate the router to have multiple routing tables as such each vrf is independent of each other, that why it lets you apply the same subnet/ip address on two different interfaces on the same devices.
Now you can route leak between the vrf routing tables and the global routing table of the router if you wish but I would suggest you change one of the vrf's address to a different subnet to avoid any conflict.
You will also need to add statics in your router to make the global rib aware of the vrf ribs.
example:
ip route vrf BBING 10.230.1.1 255.255.255 vlan 300
ip route vrf BBING 10.127.251.33 255.255.255.248 vlan 300
ip route vrf SIP 192.168.8.254 255.255.255.0 vlan 303
Also to reach another network in a different vrf you need import that prefix into the vrf table you want to use to reach the opposite vrf prefix, One way to do this is again use static routing or another way would be to import the routes via a route map.
example:
R1
vrf BBNG  1.1.1.1/32 loopback 0
vrf BBNG 10.1.12.1/24  fa0/0  <---connected to R2
ip route vrf  BBING 2.2.2.2 255.255.255.255 10.1.12.2 global
or
ip prefix-list vrf-to-R2 permit 2.2.2.2/32
route-map stan-r1
match ip address prefix vrf-to-R2
ip vrf BBNG
import map vrf-to-R2
R2
vrf SIP  2.2.2.2/32
vrf SIP 10.1.12.2/24  fa0/0  <---connected to R1
ip route vrf SIP 1.1.1.1 255.255.255.255 10.1.12.1 global
or
ip prefix-list vrf-to-R1 permit 1.1.1.1/32
route-map stan-r1
match ip address prefix vrf-to-R1
ip vrf SIP
import map vrf-to-R1
res
Paul
Kind Regards
Paul
It's not correct.
"global" is wrong option in your example.
Hello a.alekseev
From what I can see in this post - It does seem the global keyword IS required so to enable  to tell the vrf rib to check the global routing table for the router for its next hop -  However would you be explain why this isn't required -  it may be I have mis-interpreted the OP?
Also I see no mention of any routing process in the OP or from the route table output , so where does bgp come into this post?
Lastly the loopbacks was just an example of a logical connected interface in a vrf so the adjacent rtr's could access each other between different vrf tables.
Kind Regards
Paul
ip route vrf 1.1.1.1 255.255.255.255 10.1.12.1 global
first you missed vrf's name
global - where the router should look for next hop.
In you example the router should look for 10.1.12.1 in GRT.
But in your example 10.1.12.1 in vrf SIP (vrf SIP 10.1.12.2/24 fa0/0 <---connected to R1)
Hello
You correct I did miss out the vrf name - that was a typo  (now amended)- However please note this was an example of route leaking ONLY so the Op could use it to his/her own advantage
Kind Regards
Paul
a.alekseev
Level 7
Level 7
you can also do it without a loop...
run bgp
redistribute connected and static in address-family ipv4 vrf XXXX
add route-target community to the vrf definitions
make import/export policy for the vrf definitions
a.alekseev
Level 7
Level 7
Could you show the output
Sh int vlan300
Sh int vlan302
Look for mac addresses. Are they differ?
If not, try to make l3 loop between f0 - f2
P.S. as I said before there is another way to do route leaking...
yes, we will work on route leaking as well but will first focus on the physical connection.
Attached is the output: MACs are the same
sh int vlan 300
Vlan300 is up, line protocol is up
  Hardware is EtherSVI, address is e8b7.4809.6df0 (bia e8b7.4809.6df0)
  Internet address is 10.127.251.33/29
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
  Last input 01:46:20, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     3 packets input, 180 bytes, 0 no buffer
     Received 3 broadcasts (0 IP multicasts)
     35 packets output, 3450 bytes, 0 underruns
     0 output errors, 1 interface resets
     0 unknown protocol drops
sh int vlan 302
Vlan302 is up, line protocol is up
  Internet address is 10.127.251.34/29
  Last input 00:32:19, output never, output hang never
     9 packets input, 540 bytes, 0 no buffer
     Received 9 broadcasts (0 IP multicasts)
     9 packets output, 540 bytes, 0 underruns
sh arp vrf SIP
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.127.251.33          35   e8b7.4809.6df0  ARPA   Vlan302
Internet  10.127.251.34           -   e8b7.4809.6df0  ARPA   Vlan302
Internet  192.168.8.1           172   44c3.4653.07c0  ARPA   Vlan303
Internet  192.168.8.254           -   e8b7.4809.6df0  ARPA   Vlan303
sh arp vrf BBNIG
Internet  10.127.251.33           -   e8b7.4809.6df0  ARPA   Vlan300
Internet  10.230.1.1              -   e8b7.4809.6df0  ARPA   Vlan101
Internet  10.230.1.11             1   2047.47b3.de18  ARPA   Vlan101
Internet  10.230.1.12            79   ecf4.bb66.a739  ARPA   Vlan101
Internet  10.230.1.136           14   a44c.c80c.ff13  ARPA   Vlan101
Internet  10.230.1.138           87   847b.eb0b.9878  ARPA   Vlan101
as you can see .33 and .34 have the same mac  address...
so you loop will not work.
Just as an example
Router#sh ip route vrf SIP
Routing Table: SIP
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B        10.230.1.0/24 is directly connected (BBNIG), 00:07:36, Ethernet0/0.10
L        10.230.1.1/32 is directly connected, Ethernet0/0.10
      11.0.0.0/32 is subnetted, 1 subnets
B        11.11.11.11 [20/0] via 10.230.1.254 (BBNIG), 00:01:04
      22.0.0.0/32 is subnetted, 1 subnets
S        22.22.22.22 [1/0] via 192.168.8.1
C        192.168.8.0/24 is directly connected, Ethernet0/0.20
L        192.168.8.254/32 is directly connected, Ethernet0/0.20
Router#sh ip route vrf BBNIG
Routing Table: BBNIG
Gateway of last resort is not set
C        10.230.1.0/24 is directly connected, Ethernet0/0.10
S        11.11.11.11 [1/0] via 10.230.1.254
B        22.22.22.22 [20/0] via 192.168.8.1 (SIP), 00:00:39
B        192.168.8.0/24 is directly connected (SIP), 00:07:59, Ethernet0/0.20
Router#sh ip bgp vpnv4 all
BGP table version is 15, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:1 (default for vrf SIP)
 *>  10.230.1.0/24    0.0.0.0                  0         32768 ?
 *>  11.11.11.11/32   10.230.1.254             0         32768 ?
 *>  22.22.22.22/32   192.168.8.1              0         32768 ?
 *>  192.168.8.0      0.0.0.0                  0         32768 ?
Route Distinguisher: 1:2 (default for vrf BBNIG)
Router#
Router#sh run
Building configuration...
Current configuration : 1992 bytes
! Last configuration change at 13:29:55 MSK Wed Jul 25 2018
version 15.4
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
clock timezone MSK 3 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip vrf BBNIG
 rd 1:2
 route-target export 1:2
 route-target export 1:1
 route-target import 1:2
 route-target import 1:1
ip vrf SIP
 rd 1:1
ip cef
no ipv6 cef
redundancy
interface Loopback1000
 description ### for BGP router-id ###
 ip address 1.1.1.1 255.255.255.255
interface Ethernet0/0
 no ip address
interface Ethernet0/0.10
 encapsulation dot1Q 10
interface Ethernet0/0.20
 encapsulation dot1Q 20
interface Ethernet0/1
 no ip address
 shutdown
interface Ethernet0/2
 no ip address
 shutdown
interface Ethernet0/3
 no ip address
 shutdown
router bgp 65000
 bgp log-neighbor-changes
 address-family ipv4 vrf BBNIG
  redistribute static route-map STATIC2BGP
 exit-address-family
 address-family ipv4 vrf SIP
 exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf SIP 22.22.22.22 255.255.255.255 192.168.8.1 tag 999
ip route vrf BBNIG 11.11.11.11 255.255.255.255 10.230.1.254 tag 999
route-map STATIC2BGP permit 10
 match tag 999
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
 transport input none
end
