OSPF Lsa Type 2
Hi, I have a question. If there is a DR, then LSA type 2 will be sent to all other routers, but why is DROTHER also sending individual LSA Type 1? I understand LSA Type 2 a little bit, which is that it is used to obtain the information of the router presented in the same subnet and multicast network.
17 Replies 17
If you check opsf db you will see advertiser router IP' without lsa1 this IP is unknown for other router
MHM
CAN YOU EXPLAIN ME LSA TYPE 2 FROM SCRACTH BECAUSE I AM NOT ABLE TO UNDERSTAND THIS CONCEPT
Router# show ip ospf database asbr-summary
OSPF Router with id(192.168.239.66) (Process ID 300)
                Displaying Summary ASB Link States(Area 0.0.0.0)
	LS age: 1463
	Options: (No TOS-capability)
	LS Type: Summary Links(AS Boundary Router)
	Link State ID: 172.16.245.1 (AS Boundary Router address)
	Advertising Router: 172.16.241.5 <<- this IP
	LS Seq Number: 80000072
	Checksum: 0x3548
	Length: 28
	Network Mask: 0.0.0.0 TOS: 0  Metric: 1
This example of show ospf db' do for all type of lsa and you will see advertiser router IP. This IP is learn from LSA1.
MHM
Hello
This is incorrect  what you are showing there is a type-4 LSA, the command for type 2 LSA is:
sh ip ospf database network
Kind Regards
Paul
Apologies
Again you need to refresh your acknowledge.
MHM
Hello
If your suggesting that your previous example of type4 lsa is related with a type 2 then you are mistaken
What you are showing is a external type LSA 4 originated from some ABR rtr advertising a destination of an ASBR located on a rtr in one of those areas.
The OP is querying type 2 LSAs and their functionality in OSPF it has nothing to do with type 4 LSAs and their functionality
So can you explain or any other please what i need to update my knowledge of as would be happy to say i am wrong if that is the case -  as in essence that is what these forums are all about?
Kind Regards
Paul
Friend I really want to answer you but I have alot of topic need to cover
regarding LSA4 if Router send LSA4 to all routers to use this IP, how other routers know this IP ?
this job of LSA1
each routers advertise LSA1 to declare to all other routers these IP belong to me.
these IP can use for forward address for LSA4 and for other.
sorry again, if I am not answer you you can send me PM
MHM
Hello @MHM Cisco World
i will stipulate this again - a type4 has absolutely nothing to do with a type 2  and i’ve no idea what ypu are talking about in reference to the OP  what happens iif there is no muticaess network as such no DR so no type 2 what then?
So apologies I believe your understanding is incorrect not mine however  this is open to discussion to the wider audience and i’m happy to be corrected
Edited
in addition  you still haven’t explain g why would you show a command for a type 4 lsa when the command for a type  2 lsa exists ?
Kind Regards
Paul
Hello
Can you elaborate please , not sure what you mean "IP is unknown" ?
Kind Regards
Paul
Hello
If you have  DR/BDR then you have a multi access network segment, as such Type 2 LSAs advertise this and It the Drs responsibility to flood these type 2 lsas to all others rrtr on this same segment including rtrs that are DRothers.
Ospf Drothers are also rtrs obviously... and they send their own list on routed links via type 1 LSAs  (router LSAs) just like another ospf rtr would do
Kind Regards
Paul
SO TYPE 1 LSA IS ONLY SENDED TO DR ONLY
Hello
Correct to the all DR routers mc address 224.0.0.6., in turn ONLY the DR will flood it updates to the all ospf routers on  224.0.0.5 mc address
Kind Regards
Paul
Suppose that there are 5 Router. R1 R2 R3 R4 R5 R6 they are in multi access network and R1 AND R2 are DR AND BDR. There is one more router R6 which is not the part of this multi network access which is directly connected to R1 via serial cable so my doubt is either all DROTHER will send their individual LSA TO R6 or all DROTHER Router will send LSA to DR Router and then DR Router will send LSA 2 to R6 for creating complete topology of the entire network. Just clear this question
Hello
so if you have an additional rtr that is directly connected via serial as such then no DR/ DR will  it exit between RTR1 and RTR6 - you see a rtr can have various ospf network types running at the same time so even though rtr 1 is DR on one interface it can be a BDR/DRother or just a P2P on another -
as such in your example the  the ospf link type will no doubt become a P2P so no type 2 lsas will exist - the rtr wi just exchange lsa type1/2 unless either rtr is also an abr/asbr etc..
Kind Regards
Paul
