ospf MAXage problem
senthil1976
Community Member
I got a message from two ABR. message says 'Maximum age reached for an LS advertisment'. But there were not any link problems(no NMS loggs). link utilization also very small. I think that there is no possibility that ospf refresh packets would be droped. So what could be the reason for this message.
Senthil
8 Replies 8
mounir.mohamed
Level 9
Level 9
Dear senthil,
Each OSPF LSA has an age, which indicates whether the LSA is still valid. Once the LSA reaches the maximum age (one hour), it is discarded. During the aging process, the originating router sends a refresh packet every 30 minutes to refresh the LSA. Refresh packets are sent to keep the LSA from expiring, whether there has been a change in the network topology or not. Checksumming is performed on all LSAs every 10 minutes. The router keeps track of LSAs it generates and LSAs it receives from other routers. The router refreshes LSAs it generated; it ages the LSAs it received from other routers.
for more information kindly check:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1826/products_feature_guide09186a0080087d4d.html
Please rate helpful posts.
Best Regards,
Mounir Mohamed
Thanks Mohamad,
Actually I knew the concept of the ospf refresh packets. But in my problem I got an MaxAge reached problem for an LSA. this means there was a drop of ospf refresh packet. But this is to happen there should be a link down or link congestion. But there was no evidance for link down or link congestion. so I am seprise that what could be the reson for drop of ospf refresh packet.
Senthil
Senthil,
Is this a multi-vendor network?
Hi Hritter,
No. It is under administration of single vender. But the both ABR are GSRs.
Senthil
Thanks for the feedback. I had seen a simular issue but it was related to a minor interoperability between Cisco and an other vendor. I guess it doesn't apply to your case then.
Cheers,
Thanks Hritter.
Hi Guys,
I really need to know that is there any possiblity to drop ospf referesh packet with out any congestion in links? Or what are the possiblities that summary LSA reaches the MaxAge except following reasons,
1) Refresh packet does not received
2) lack of sequence number for ospf process
Senthil
CSCO10899265
Community Member
Have any of your ospf areas been translated as a stub or NSSA AREA? If so this situation is entirely possible
Nimesh Amin
There is no stub or NSSA area.
what is the reason to happen this in case Stub or NSSA area is there?
Senthil
