OSPF MD5 Key Rollover
mmurray
I'm using MD5 auth on a virtual link and need to understand the key rollover process. I initially configured the routers (7206VXR, 12.4(15)T7) as follows:
R3:
router ospf 1
router-id 3.3.3.3
log-adjacency-changes
area 2 virtual-link 4.4.4.4 authentication message-digest
area 2 virtual-link 4.4.4.4 message-digest-key 1 md5 CISCO
R4:
router ospf 1
router-id 4.4.4.4
area 2 virtual-link 3.3.3.3 authentication message-digest
area 2 virtual-link 3.3.3.3 message-digest-key 1 md5 CISCO
The virtual link came up fine:
R3(config-router)#do sho ip ospf virt
Virtual Link OSPF_VL2 to router 4.4.4.4 is up
Run as demand circuit
DoNotAge LSA allowed.
Transit area 2, via interface Serial1/0.34, Cost of using 64
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
Hello due in 00:00:09
Adjacency State FULL (Hello suppressed)
Index 2/3, retransmission queue length 0, number of retransmission 0
First 0x0(0)/0x0(0) Next 0x0(0)/0x0(0)
Last retransmission scan length is 0, maximum is 0
Last retransmission scan time is 0 msec, maximum is 0 msec
Message digest authentication enabled
Youngest key id is 1
Then I changed the keys as follows:
R3(config-router)#area 2 virtual-link 4.4.4.4 message-digest-key 2 md5 CCIE
R4(config-router)#area 2 virtual-link 3.3.3.3 message-digest-key 2 md5 CCIE
On both routers:
show ip ospf vir
Rollover process begins....
Youngest key id is 2
Rollover in progress, 1 neighbor(s) using the old key(s):
key id 1
Then I remove the old keys:
R3(config-router)#no area 2 virtual-link 4.4.4.4 message-digest-key 1
R4(config-router)#no area 2 virtual-link 3.3.3.3 message-digest-key 1
And I still see the rollover process in effect on both routers:
The output is the same from both routers. My virtual link is still up and OSPF is functioning correctly. But why am I still getting this message?
A show run confirms that key 1 no longer exists:
router ospf 1
router-id 3.3.3.3
network 3.3.3.3 0.0.0.0 area 0
network 30.3.3.3 0.0.0.0 area 2
network 131.1.23.3 0.0.0.0 area 0
network 131.1.34.3 0.0.0.0 area 2
router ospf 1
router-id 4.4.4.4
network 4.4.4.4 0.0.0.0 area 2
network 40.4.4.4 0.0.0.0 area 4
network 131.1.34.4 0.0.0.0 area 2
network 131.1.45.4 0.0.0.0 area 4
Any ideas? thanks.
Giuseppe Larosa
Hello Michael,
try to repeat the tests using
• debug ip ospf event
• debug ip ospf packet
• debug ip ospf hello
to see how the smooth change of key is implemented: the sending of two copies of each hellos one with key1 and one with key2.
Hope to help
Giuseppe
