OSPF Metric
hs08
I have topology below.
From R1 perspective when i issue show ip route 10.103.248.0 i got
Routing entry for 10.103.248.0/24
Known via "ospf 100", distance 110, metric 43, type inter area
Last update from 10.102.200.2 on GigabitEthernet1/0/2, 1d06h ago
Routing Descriptor Blocks:
10.102.200.2, from 10.103.103.5, 1d06h ago, via GigabitEthernet1/0/2
Route metric is 43, traffic share count is 1
* 10.102.173.10, from 10.103.103.5, 1d22h ago, via GigabitEthernet1/0/1
The route metric for both path is 43, this metric is cost from R1 to R2 and from R1 to R3? If true, why the metric is 43 and not 2? The link between R1 to R2 and R3 is 1Gbps.
Hello @hs08 ,
is R6 a Nexus running NX OS ?
they have a different default reference bandwidth for OSPF it is not the same value used by IOS XE or IOS .
you can check this with
show ip ospf
Hope to help
Giuseppe
12 Replies 12
Hello
The cost is the forward metric to reach the ABR of the area that is adverting the prefix
Kind Regards
Paul
Can you explain more specific? I already add the ospf area in the picture.
No
From R1 to R2/R3 plus R2/R3 to R4/R5 plus R4/R5 to R6 plus link connect to R6
It cost for all link along path.
MHM
Ok noted,
i can see the metric from R5 to 10.103.248.0 is 41 this mean metric from R1 become 43 due 42 plus R3 to R5 plus R3 to R1, am i correct?
Now the question is why metric from R5 to 10.103.248.0 is 41?
this from R5
Known via "ospf 100", distance 110, metric 41, type intra area
Last update from 10.103.245.9 on GigabitEthernet0/0/0, 7w0d ago
* 10.103.245.9, from 10.103.103.1, 7w0d ago, via GigabitEthernet0/0/0
Route metric is 41, traffic share count is 1
here R5 config for int g0/0/0
interface GigabitEthernet0/0/0
ip address 10.103.245.10 255.255.255.252
ip ospf network point-to-point
ip ospf 100 area 0.0.0.0
negotiation auto
And here config on R6
interface Ethernet2/17
ip address 10.103.245.9/30
ip router ospf 100 area 0.0.0.0
no shutdown
Friend
I already share command with small lab in your other post
You need to use
Show ip ospf database route <- for intra
To see cost for each link
Show run don't give you anything
MHM
Noted
Hello @hs08 ,
show ip ospf
Hope to help
Giuseppe
Hi..
Yes correct, when i check on the documentation the NX-OS use 40Gbps for bandwidth reference, so R5 will have metric 41. This make me understand from R1 the metrcis is 43.
MHM
Hi..
From R5 perspective the cost to 10.103.0.0/16 is 41, so there will be 2 costs, one from R5 to R6 and R6 to the host?
NX-OS use 40Gbps for reference bandwidth, this mean :
Cost from R5 to R6 is 4, and from R6 to the host is 1? If true, why cost from R6 to host is not 4? In my mind cost from R5 to R6 will same with R6 to the host, so the total cost should be (40 + 40 = 80).
Hello
R6 suggest its an ABR between Area0 and another area, as such a type ospf 3 lsa will be advertised  into Area0 by R6 for that prefix its adverting
OSPF rtrs in area 0 will then have forward metric calculation based on the route path to reach R6 ABR
Kind Regards
Paul
Hello
LOL - apologies my mistake your ABRs are both  R4/R5, so the calculation is the advertised type 3 LSA  from either R4/R5 (41)and the ospf metric to reach both R4/R5 (2)
Kind Regards
Paul
