Ospf multiple area problem
Ahmed Chowdhury
Level 2
Level 2
hi ,
      i have 7 routers in my wan topology. one router is hub(HQ) and rest of the are spokes(Branches). i configured gre over Ipsec vpn.now
how do i configure them in multiple ospf area so that my HQ router will be area 0 and the branches are like 2, 3, 4 area. i also want that my branch routers dont receive all HQ routes. in this case i have to do stub area but i also read that stub area is only blocking external routes and i dont have any external routes. so what should i do now. thanks in advanceee...
9 Replies 9
Yasir Ashfaque
Level 5
Level 5
Just configure it as totally stubby area, as your Spokes will be in different areas,  HQ will only advertise the summary default route to spokes.
Yasir
Thanks bro one more question is that now  the local lan of the  hub will be area 0 and the respective branch tunnels(WAN) will be different area.rite..correct me if i am wrong.thanks in advancee..
Yes, it will work in this way too.
Thanks bro and one more thing is that multiple ospf is working fine.then i configured the spokes as totally-stubby but then i cant ping any other remote branches. any suggestions will be really appriciatable.thanks in advanceeee.
Can you share the output of following commands, on HQ and any two spoke.
show ip ospf interface brief
show ip ospf nei
show ip route ospf
HUB Router:
HUB-Router#show ip ospf interface brief
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
Fa1/0        10    0               192.168.1.1/24     1     DR    0/0
Tu1          10    1               200.200.200.2/30   11111 P2P   1/1
Tu2          10    2               200.200.200.6/30   11111 P2P   1/1
Tu3          10    3               200.200.200.10/30  11111 P2P   1/1
HUB-Router#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
200.200.200.1     0   FULL/  -        00:00:33    200.200.200.1   Tunnel1
200.200.200.5     0   FULL/  -        00:00:36    200.200.200.5   Tunnel2
200.200.200.9     0   FULL/  -        00:00:36    200.200.200.9   Tunnel3
HUB-Router#sh ip route ospf
O    192.168.13.0/24 [110/11112] via 200.200.200.5, 00:07:20, Tunnel2
O    192.168.36.0/24 [110/11112] via 200.200.200.1, 00:07:20, Tunnel1
O    192.168.53.0/24 [110/11112] via 200.200.200.9, 00:07:30, Tunnel3
SPOKE-1
SPOKE-1#show ip ospf interface brief
Tu0          10    1               200.200.200.1/30   11111 P2P   1/1
Fa1/0        10    1               192.168.36.1/24    1     DR    0/0
SPOKE-1#sh ip ospf neighbor
200.200.200.10    0   FULL/  -        00:00:29    200.200.200.2   Tunnel0
SPOKE-1#sh ip route ospf
     200.200.200.0/30 is subnetted, 3 subnets
O IA    200.200.200.8 [110/22222] via 200.200.200.2, 00:11:44, Tunnel0
O IA    200.200.200.4 [110/22222] via 200.200.200.2, 00:11:44, Tunnel0
O IA 192.168.13.0/24 [110/22223] via 200.200.200.2, 00:11:38, Tunnel0
O IA 192.168.53.0/24 [110/22223] via 200.200.200.2, 00:11:44, Tunnel0
O IA 192.168.1.0/24 [110/11112] via 200.200.200.2, 00:11:44, Tunnel0
SPOKE-2
SPOKE-2#sh ip ospf int br
Tu0          10    2               200.200.200.5/30   11111 P2P   1/1
Fa1/0        10    2               192.168.13.1/24    1     DR    0/0
SPOKE-2#sh ip ospf nei
200.200.200.10    0   FULL/  -        00:00:32    200.200.200.6   Tunnel0
SPOKE-2#sh ip route ospf
O IA    200.200.200.8 [110/22222] via 200.200.200.6, 00:13:49, Tunnel0
O IA    200.200.200.0 [110/22222] via 200.200.200.6, 00:13:49, Tunnel0
O IA 192.168.36.0/24 [110/22223] via 200.200.200.6, 00:13:44, Tunnel0
O IA 192.168.53.0/24 [110/22223] via 200.200.200.6, 00:13:49, Tunnel0
O IA 192.168.1.0/24 [110/11112] via 200.200.200.6, 00:13:49, Tunnel0
I think you have not configured it as totally stubby, and from the routing table things seems to be ok.
Thanks a lot buddy. now its working finee.thankssss..............
